f5e1 is a door locking error. try shutting off power for a minimum of 2 minutes to reset the control board. If you still get the error replace the latch. Here is the part to order.
F4 Meat probe shorted 1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C], 37kω at 90° F [32.2° C]). 2. If resistance is not valid replace probe. 3. Insert probe and check for a firm connection between probe and jack (in oven cavity). 4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Remove the oven from the wall. Remove the rear panel. The upper and lower ovens have a non-resettable thermal fuse that has blown. Use a VOM to verify which fuse. After repair use Easy Off, not self clean.
