Beaters vibrate and hit side of bowl
Your worm gear is no longer seated and that is more than likely because the housing cover is probably the old style plastic and it has cracked which allows the worm gear to jump up during operation and turn out of sync. The worm gear turns the drive gear that works the planetary gears which in turn drives the beater. If the worm gear is not turning true then of course it is pushing the planetary out of true as it turns, which causes the beater to slam the sides of the bowl. The question is this...does the beater hit the bowl in the same place on the bowl every time? Or does the beater hit the bowl in different places every time? If it hits the same place then it is probably just a planetary gear of which there are four gears involved and it could be any one of them. It it hits a different place every time it is most likely the worm gear and cover. In either case parts will cost between 30 and 50 dollars. and it takes about an hour to fix.
Try lowering the bowl by removing the pad below the base of the bowl.
SOURCE: Kitchen aide mixer
i noticed my kitchen aide mixer is sounding like it is bogging down slightly while it is running it is not used very much and bought christmas 2007 others who own them have said theirs doesnt do that should i be concerned
SOURCE: vibrates and beater hits bottom of bowl
Try adjusting the height of the head by turning screw #36 counterclockwise a turn or so. This will raise the mixing head so the beaters no longer hit the bottom of the bowl. Refer to parts list:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
If the pivot pin #18 is not centered and secured then center the pin and turn the mixer on its side to tighten screw #31 from underneath the mixer to secure the pivot pin.
