Televison & Video Logo
Posted on Jul 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote does not work - Samsung SyncMaster 323T 32 in. HD-Ready LCD Television
Anonymous
Level 2:
  • Expert 304 Answers
  • Posted on Jul 17, 2009
Anonymous
Expert
Level 2:
Answers
304
Questions
Helped
118054
Points
474
You have either accidently turned "off" the control selector in the user menu or you may have a bad IR sensor in the tv. Will the tv turn on with Power button on the tv itself?
My remote start quit working all of a sudden. The lights and everything comes on like its supposed to but it doesn't start. The remote still locks and unlocks
My Remote Car Starter Stopped Working! - DON'T PANIC!
www.mobileedgeonline.com > Remote Car Starters
This time of the year rarely a week goes by that we don't get a call from someone stating that their remote car starter stopped working. Nearly every call is the ...
So Your Remote Starter Stopped Working.... Just Relax!
www.wssdriveeasy.com/remote-starter-stopped-working/
Sep 29, 2013 - You press the button on a cold Winter day to find that your remote starter stopped working! Take a deep breath. It is probably something very ...
My remote starter is not working, how do I fix this? - Compustar
https://support.compustar.com/.../202533874-My-remote-starter-is-not-w...
When your vehicle's remote start stops functioning the solution can change depending on each situation. The Compustar remote will not...
Remote Starter Won't Start - YouTube
? 1:02
https://www.youtube.com/watch?v=EuHu2VFx0ks
Nov 4, 2012 - Uploaded by daniluchison
Remote controls sends signal to Remote Starter but after a few 'clicks' it won't start the ... 04-08 Pontiac ...
remote start problems - YouTube
What rs remotes will work with a rca rs2610 book shelf stereo?
Remotes.com has a replacement remote that will work here: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=+rs2610&uuid=14001121456810 . The original remote has the part number: ZA90459 . If you can find this remote, it would work. The other models of RCA RS stereo remotes won't work.
I hope this helps.
2answers
My remote was working fine until i moved. I have Direct Tv and the remote from Direct Tv works on guide. I bought a new remote from Magnavox but it doesn't work my tv. what should I try? '
You have to program the remote control to synchronize with TV. If you wish to get moredetails; codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
My remote wont work rca 40 inch lcd
Check the remote by looking through a digital camera at the remotes light while pressing the remote buttons if you see the light then the remotes working and you most likely need to replace the IR sensor. You can get the remote and the IR sensor from www.tvrepairworld.com
Wii remote not working?
You got to sync the remote with your console to activate the remote
Remote start wont work
Does the remote work? If the remote is working, then check the hood pin. Hold down the hood pin and remote start the vehicle with the remote. If the remote start fails to work,check the neutral safety shutdown switch. It's a toggle switch under the dash.
1helpful
I have 2 fans 1 stopped working 1 remote
Look at the remote code on the remote which is broken, then copy the code on the fixed remote, then you can control anoher fan.
2answers
Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
3answers
Touch Screen and Remote Problem
My remote stop working. I replaced the 2 AA batties by still does not work
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
