Mitsubishi Diamond WD-65831 65" Projection HDTV Logo
Stephen Zalewski Posted on Dec 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What part do I need to replace when my DLP tv bulb cracked after I turned off the tv?
Replaced the DLP chip successfully. Replaced one of the fans. My brand new bulb craked about 20 seconds after I turned off the tv.
Terry Dovre
Level 2:
  • Expert 195 Answers
  • Posted on Jan 31, 2015
Terry Dovre
Expert
Level 2:
Answers
195
Questions
0
Helped
27039
Points
406
Hello, all i can say is it may have been a bad lamp, see if they'll warranty it....tks
5 Related Answers
electroman
  • 1039 Answers
  • Posted on Apr 25, 2009
SOURCE: Mitsubishi 57" DLP. Replaced bulb, now picture is hazy.
Cleaning th mirror and lense will remove the haze. This oldel is much older that 2 years though.
Anonymous
  • 1779 Answers
  • Posted on Feb 14, 2009
SOURCE: Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Anonymous
  • 179 Answers
  • Posted on Dec 18, 2008
SOURCE: Status Light flashing yellow after replacing the bulb
your air filter cover is loose or not on.
Anonymous
  • Posted on Nov 24, 2009
SOURCE: Just replaced the bulb in my wd-62528 dlp tv,
Hi, I'm not a service expert. I too own a WD-62528 DLP TV with exactly the same problem. Manufacture date Nov. 2005.
I have found in another forum (CNET) that this is a very well known problem. And that Mitsubishi (MDEA) is not taking responsibility for it. A group of people tried to make a Class Lawsuit but it was rejected. Also other people found that this TV actually does not display 1080i resolution, that is a separate problem from the lamp issue.
If you are able to solve this problem with the TV (blinking lights requesting a new lamp all the time and TV turning off by itself), please let me know. If you want a link to the other forum, let me know and I will send the link.
Also, please don't be discouraged from trying to find a solution. Keep trying.
Jorge Aguilar
Houston
Anonymous
  • 5138 Answers
  • Posted on May 09, 2010
SOURCE: My lamp on my Mitsubishi WD65733 DLP TV actually
No check for bad capacitors on Power supply board they will be vented swollen or puffed up on top.
Go to Encompass Parts Distribution and look up your Model number.
2answers
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Need help, what can be wrong at this point. Have tried several test and replaced the color wheel, but nothing was or is making any noise ??
I think you have lost the fan. Check the installation and make sure the fan switch is activated. You must have a fan going or the bulb will actually burnout soon that is why the fail safe circits are shutting it down; to keep the lamp from burning up. Got to get the fan going.
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
1helpful
2answers
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
2helpful
2answers
Light bulb
White dot for DLP Projector TV is not because of the light buy. It is caused by aging DLP chip ( DMD Chip.) Your TV DLP Part should be the following image:
Check the post how to place it diy
HLP5667WX LIGHT FAN NOT TURNING
Hello
Check all the connections of the set. A light replacement only could cause this problem.
3helpful
2answers
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
I just replaced the DLP Lamp and housing on a 50' Samsung DLP tv.
CK your Fans make sure they are running or set will not come on.also if you can solder resolder power supply board.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
