When we are talking on the phone it will just go out and we lose calls. We get a IP Fail message follow by message saying System is upgrading. We really need to resolve this because we are a business.
SOURCE: Night Service and Diver All Call to Voice Mail
make sure the call rerouting always is setup and points to the vm huntgroup, then check the call rerouting assignment points the answer point extn number to the relevant always alternative in night1 and night2 mode
ie; always alternative 10 set all to Reroute and supply vm huntgroup number then program call rerouting assignment for extn during night1 and 2 to 10.
let me know if this resolves the issue if not it could be a number of other timer related / vm configuration / call routing problems which might require a more indepth investigation
SOURCE: mitel 5220 ip phone locked out
Make sure that it is a Dual Mode 5220. If it is you can use it as a SIP extension. It wiill say it on the back of the Mitel phone next to the 5220.
If it is a dual mode phone you can purchase a sip trunk from a provider and then would be able to use the phone.
When you boot up the phone hold the blue super key while the phone boots, hit the no softkey till you get to phone mode. Hit yes it will allow you to change the phone from minet to sip. This should get you started in the right direction.
SOURCE: Cannot get incoming calls on
Your phone is in Do-Not-Disturb. Press the blue superkey. Press No until you see DND or Do-Not Disturb and press yes... press Turn off.
on this phone, the * and # are the keys for yes and no.
SOURCE: How do I change voicemail message one line of on
Log into your mailbox. Press U for user options, and G for greeting... follow the prompts for changing it.
SOURCE: My 5340 IP phone doesn't
Here is a link to the main Mitel Support page for your model:
http://www.mitel.com/DocController?documentId=19423
And here is a direct link to the online user's manual for that model:
http://www.ebiz.mitel.com/images/email/Telephone_Demos/53405Kdemolist.html
To select a ringtone, press 398 while the handset is in the cradle and then use the UP / DOWN ARROW keys to select a ringtone as per the demonstration at the following link:
http://www.ebiz.mitel.com/images/email/Telephone_Demos/demos/5340_5kl2_ab.swf
Then press the SPEAKER button to save your selection.
To change the handset volume levels use the UP / DOWN ARROW keys as per the demonstration at the following link:
http://www.ebiz.mitel.com/images/email/Telephone_Demos/demos/5340_5kl2_aa.swf
To activate or disable the DO NOT DISTURB FEATURE of the phone, just follow the instructions in the demonstration at the following link:
http://www.ebiz.mitel.com/images/email/Telephone_Demos/demos/5340_5kl1_u.swf
Detailed instructions for all of these features and more can be found in the MITEL INTERACTIVE USER'S GUIDE at the following link:
Just use your mouse to click on the links, which are the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
Joe.
