Press SHIFT MODE 8 2 to select the Norm2 display mode, which will display in fixed decimal notation unless the magnitude of the number is larger than 10^10 or less than 10^-9
For more information about the display modes, please refer to your manual.
1) Press the Mode button. 2) Scroll down the list that appears until you find "Exact/Approx". 3) Change the setting for "Exact/Approx" to Exact. 4) Press enter to save the settings change.
You have three possible settings for "Exact/Approx": 1) Auto - The calculator will try to determine the best format. 2) Exact - The calculator will always give the answer in fraction form. 3) Approximate - The calculator will always give the answer in decimal form.
1) Whenever you want the answer in decimal form, place a decimal after at least one of the numbers. For example: instead of using (1/2) use (1/2.)
2) Press the "Mode" button. Scroll down the list that appears until you find "Exact/Approx". If you set it to "Approximate", then it will always give the answer in decimal form. If you set it to "Exact", it will give the answer in fraction form.
