Yess the DDR5511R has the drain hose connection inside the compartment where the water bucket sits. It is at the top right corner. You have to remove the water drawer to see it. At the right side of the unit (on the outside) is a small "door" that flips up so that you can feed a hose throught to the threaded outet inside. The drain hose is not supplied with this unit.
No. The tube inserts straight into the drain hole. Follow the 4 sets below.
1. Connect a garden hose to the threaded drain hose connector. 2. Remove the drain-hole cover. 3. Push hose connector tightly into the drain-hole on Rear Grille. 4. Press the hose down and make sure the "Arrow" on the tab is pointing upward.
NOTE: The hose attachment will accept a standard garden hose fitting. Do not over tighten the hose when connecting it to the hose connector, use a rubber washer and tighten by hand firmly without stripping the plastic threads. Be sure the hose lays flat and has no kinks, as it will not drain properly.
The water collection bucket may have a hose tap in it. But, in your case the hose drain connection is on the side of the unit. You have to remove the cover of the hose connection, before you can connect the garden hose. Here's where it gets a little tricky, because the Owners Manual says to leave the bucket in place. However, the Troubleshooting Guide says to remove the bucket, if water is not draining thru the hose. Which to me, makes sense, because the unit can't recognize that the hose is connected, if the bucket is still installed, because it has a safety switch.
In case you have misplaced your Owners Manual, here is a link to it, that you can download and print for future reference.
If you want to use the bucket to collect the water cover the hole in the back where the hose to dispense water outside would normally go. You need a rubber cover that will fit tightly, it should have come with the unit.
Check for crub which may be blocking the drain hose. Blow the hose out by connecting it to your outside garden hose and turning on the water full force. Then reattach it to your dehumidifier.
(assumming you are not an idiot, like the other solver suggested) you may very well have it connected to the right spot, many of these units, are not balanced well, (or are balnaced all to well, depending on how you look at it) The imbalance, basically makes the water drip to the front, instead of the back. Try to put something under just the front of the machine, to tilt it back, ever so slightly. Good luck
I fixed the same problem, finally. At first it was sufficient to clean the outside hose (it was filled with a **** builtup). Then it stopped working again. I decided to open the unit and see how easy it is to clean the inside drain hose. It is very easy. Once you unscrew the back panel (8 screws total if i remember correctly) you can access the back and you see the drain hose that connects to the drain outlet. To remove it and clean it, you will have to unfasten the big capacitor (3 screws). Then, remove the hose and clean it (mine was full of that same **** stuff). Reinstall - you will need a tie wrap to connect the hose at the top, as it is from the factory. Very easy operation and now the dehumidifier is draining again.
I have the same problem and after talking (mostly waiting) with Fedders repair, I have been told how to solve the problem. Plug up the drain hole on the right side (the one not connected to the drain hose). The drain hole extends down about 5mm, outside measures 10mm and interior measures 7mm. They do come with a drain hold cover. Not a replaceable part with a number. Off to the hardware store.
