Dell Optiplex 755 Desktop Desktop Computer  Logo
c
cirdec cayano Posted on Oct 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im in the philippines, just want to ask where to buy i/o panel of dell optiplex 755, because i have one but was recently damaged.
Carlos Krue
Level 2:
Scholar:
  • Expert 175 Answers
  • Posted on Oct 16, 2014
Carlos Krue
Expert
Level 2:
Scholar:
Answers
175
Questions
0
Helped
21302
Points
247
I used google to search for i/o panel of dell optiplex 755 and got his link http://www.discountelectronics.com/product?gclid=CKTSgfHdscECFeHm7AodD1wA3w&product_id=7297&product_model=18
5 Related Answers
Anonymous
  • 327 Answers
  • Posted on Jul 16, 2008
SOURCE: Not able to find any drivers for Dell optiplex 755 for windows server 2003 OS
Welcome to FIXYA
there are a few websites i use might like to try them
drivers.com is a good one and driversupdate.org is also a good one
hope this halps you out ...have a good day:)
Anonymous
  • 123 Answers
  • Posted on Apr 24, 2009
SOURCE: dell optiplex 755 does not recognize the dvd-rom
Try the fix listed here - the Fix It image.
http://support.microsoft.com/kb/314060
Anonymous
  • 190 Answers
  • Posted on Jun 23, 2009
SOURCE: does a firmware update for dell optiplex 755 optical drive fix
dell 755 drivers page
your looking at the wrong firmware
optiplex 755 current bios version: A10 date 6/20/2008
for the CD Drive need to open device manager and check
what brand and model you have for dell used 2 DVD drives
b0a7e29.jpgsony and teac
use the correct firmware on drive, if not the drive will be killed.
if unsure open case and look for name/model on sticker of drive
fredtmccoyjr
Fred McCoy
  • 380 Answers
  • Posted on Jul 21, 2009
SOURCE: the OPTIPLEX 755 will not start
Open the case and look at the little black round things that look like soda cans. Those are called Capacitors. they are kinda like small batteries. They should have a shiny silver top. If they have anything oozing out or if they look like theyve popped like a popcorn kernel, then you have a faulty board. If your pc is under warranty, call dell asap. its an easy repair and its done the next day.
proton77
Mandeep Singh
  • 1184 Answers
  • Posted on Aug 30, 2010
SOURCE: I have Dell Optiplex 755
The problem of blinking amaber light is usually caused due to a bad power supply on the computer. Open the system tower and reseat the biggest bunch pf cable connected to the motherboard. its titled P1 and it the biggest white connector. If the same doesnot resolve the problem you would have to replace the power supply on the motherboard.
Thanks for using Fixya
Proton
How do I find Bluetooth on dell optiplex755 small tower
Hi juan...
You do not have Bluetooth on the Dell OptiPlex 755, but you can buy a "Bluetooth Dongle" very cheaply from the internet.
It is a plug and play you insert into the usb port and then you have Bluetooth.
Bud
Go to the following webpage to see a Bluetooth dongle
http://www.amazon.com/s/ref=nb_sb_ss_i_0_16?url=search-alias%3Daps&field-keywords=bluetooth%20dongle&sprefix=bluetooth+dongle%2Caps%2C731&rh=i%3Aaps%2Ck%3Abluetooth%20dongle
Bud
I got a dell optiplex 755 base unit from work as they were throwing them out but I cannot get a picture on 2 different monitors,no beeps no bios nothing.I connected a key board and mouse (both usb).Unit...
I recently worked with a couple of used Dell desktops that someone got from work. Sound familiar? I couldn't get them to come on because the plastic bracket that holds down the CPU heatsink was broken. The heatsink was also covered with a carpet of dust. The new owner could've bought a new heatsink/bracket online, but they declined to spend money. Open it up, make sure everything is in order to diagnose the problem.
1helpful
What is the memory module used in dell optiplex 755 service tag-9sc3jh1-dy
Dell Optiplex 755 supports a maximum of 8GB of memory. Memory modules should be installed in pairs of matched memory size, speed, and technology. If the memory modules are not installed
in matched pairs, the computer will continue to operate, but with a slight reduction in performance.
DDR2 Synch DRAM Non-ECC Memory 667MHz or 800MHz speeds are supported.
For further details please refer to Product Technical Specs (Page 12)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Is SATA ii compatible with Dell 755?
Yes the Dell Optiplex 755 desktop uses SATA II connections.
Does a firmware update for dell optiplex 755 optical drive fix intermittent rebooting issue
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
