Refrigerator not cold enough at highest setting. Temperature stays around 52 degrees F.
SOURCE: My freezer remains cold at the proper temperature
That is way too warm for a refrigerator, those temps are unafe to keep food - it should be no warmer than 40F, and optimally 34F. For your freezer no warmer than 10F, optimal is 0F and colder.
If your freezer is within those temps, then your evap fan is working normally - you might want to have your damper checked - it is a flap that opens and closes as needed to circulate cold air to your refrigerator - if this damper is stuck and woN't open or open wide enough your refrigerator won't get the needed cooling.
You might want to check for leaky gaskets in your door.
SOURCE: My Samsung Refrigerator can not keep the set temperature.
Normally your fridge is set +2 degrees C. with a differential of 3 so when it reaches +5 it should switch back on. if this is not doing this then a new thermostat may be in order.
SOURCE: The door on the refrigerator
Check the hinges for any bends, loosening or other damage. Also check the gasket (door seal) along it's entire length for any spots that may have torn or came loose from the door. Closing the refrigerator door creates a vacuum that helps keep the door closed; thus if it cannot seal it may open. Also check the entire surface of where the door gasket will contact the refrigerator chassis for anything that would disrupt the seal...it should be clean.
SOURCE: My refrigerator is not cold enough. I keep setting
Hi, If
you are hearing a clicking or buzzing then check out the last two
tips.
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
SOURCE: refrigerator temp too cold. won't stay at 34
Hi, There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems. Refrigerator is Too Cold and Freezing Food heatman101
