Automatic time set is off by exactly 10 minutes (slow)
SOURCE: Emerson Research Clock modelSmartSet
The problem is most likely the frequency of the A/C power there. In the US our power runs at 60 cycles p/second and the alarm clock uses this to set the time. Sounds like India is running 50 cycles like Europe does. Most likely there is a jumper in the clock because the Ckt board on mine shows a 50/60 hertz setting but with out the board schematics I wouldn't have a clue how to fix it. Sorry not to help more...
SOURCE: RCA RP5435B SN.1A006J255A0594-Clock running slow
Most of the Radio clocks by RCA are meant to be used with 60Hz AC line. This problem will not go away unles you can get a custom built 60 Hz AC power supply, may prove to be too expensive for the clock.
SOURCE: Time Display
A-ha! Those manuals sure do come in handy sometimes. I found the solution. In addition to functioning as a snooze button for delaying the alarm, the snooze button is also a brightness button for the time. If you press snooze one time it changes the time brightness from bright to dim, press it again and it goes from dim to motion sensitive only, press it again and it returns to bright.
I just tried this and resolved my problem. I hope it helps you as well.
Enjoy!
SOURCE: I purchased an RCA RP 5430 clock radio new in the
Here the user guide:
Manual : RP5430.
Click the link above, you will need to use the zoom option on adobe acrobat, as the manual is printed all in one big foldable page.
SOURCE: Bose radio display doesn't show at all
I just posted a similar problem and did 2 more minutes of research on this site to figure it out. Hold down the 'cd mode' and press the on/off button. This turns the display on or off.
