If the LAN driver is showing up ok as per the device manager then try these steps:
First with everything on (ISP modem and computer) open your browser and now look to see where the cable enters your network card. You should see one solid light and one flashing light.
If there is only the solid light, check to make sure the cable is pushed all the way in (or try another cable if you have one).
If that didn't work try this: Turn both your modem and computer off. Now, you need to try turning them both on at exactly the same time. Check to see if the network is now working.
SOURCE: how to find intel desktop board d845gvad2 ethernet drivers for xp
Hi vasanthkisho, click on the link below;
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=898&lang=eng
Click on the dropdown menu & choose your windows operating system. All the Intel MB drivers are listed on the site. Under drivers, pick number 3.
Run into a problem, post here.
Good luck vasanthkisho!
Mike
SOURCE: I cant install the LAN driver for Intel 845 motherboard
Here is the link for the download. it gives a list of the supporting motherboard models as well.This drive only supports OS:Windows* 2000, Windows* XP Home Edition, Windows* XP Professional
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=889&DwnldID=5406&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
hope it works. cheers
SOURCE: LAN DRIVER
http://www.gigabyte.us/Support/Motherboard/Driver_Model.aspx?ProductID=2415
here u can download...
