20 Most Recent Samsung X05 Notebook Questions & Answers
SamsungX05 ınternet problem
Windows XP Latest Drivers Windows XP Previous Drivers Windows 2000 Drivers
5/26/2020 3:36:10 PM • Samsung X05... • Answered on May 26, 2020
2answers
Ive lost the connector between my hdd and my samsung xo5
Your best bet is Ebay.
10/29/2019 12:18:38 AM • Samsung X05... • Answered on Oct 29, 2019
I am using laptop Samsung x520 and it has no CD
Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Not all of them at once. Only one. The hot key varies from model to model. There will be a brief message on the first screen you see when the computer is starting up telling you which button to push for "system setup". If unsure boot the computer and watch closely and note the button to push. Then hold down the power button until the computer restarts and be ready to hit that hot key.
Choose to enter BIOS setup.
Use the arrow keys to select the BOOT tab.
Find your preferred, always boot to first disk, and give it priority,,,( move it to the first position in the list) and then hit F10 save and continue. Your computer should reboot to the drive you selected.
10/5/2017 6:55:48 PM • Samsung X05... • Answered on Oct 05, 2017
We have one of these without a battery but have the power lead. All the lights turn on but hte screen is black. Do we need the battery pack for the screen to turn on?
There is no need of battery when your laptop is on ac power so check if there is an other problem take it to nearest workshop
7/6/2015 10:46:07 PM • Samsung X05... • Answered on Jul 06, 2015
2answers
Can Windows 7 be installed on X05? I get ACPI
The only issue i can see is if your your ram has not been updated since leaving the factory, you will notice from the tables W7 requires a min of 1GIG and your machine leaves the factory with 256mb(dependant on country possible) so check your ram. I run windows 7 on 2GB and its great, your machine will take 2GB. The Samsung X05 was released 2004 and the NVIDIA Geforce 4 should be fine. i would point out drivers and compatability but windows 7 so far is really good but driver support is crucial
hope this helps
Here is the requirements for Windows 7
Windows 7 minimum specs
  • 1GHz CPU
  • 1GB of RAM
  • 16GB of drive space
  • DirectX 9-capable graphics card or integrated chip (true of most releases 2002 and after)
  • BELOW YOUR MACHINE SPEC
  • MPN nx05tp8e0a/suk
    Key Features
    Laptop Type Thin and Light Laptop
    Use Corporate Business • Small Business • Business
    Processor Pentium M 1.5 GHz
    Installed Memory 256 MB (DDR SDRAM)
    Display 14.1 in. XGA TFT LCD
    Operating System Microsoft Windows XP Professional
    Mobile Technology Intel Centrino Mobile Technology
    Processor
    Processor Manufacturer Intel
    Processor Type Pentium M
    Processor Speed 1.5 GHz
    Motherboard
    Chipset Intel 855GM
    Bus Speed 400 MHz
    Memory
    Installed RAM 256 MB
    RAM Technology DDR SDRAM
    Max Supported RAM 2 GB
    RAM Speed 333 MHz
    Installed Cache Memory 2048 KB
    Hard Drive
    Hard Drive Capacity 30 GB
    Storage Controller Type Ultra ATA 100
    CD / DVD
    CD / DVD Type CD-RW/DVD-ROM
    Optical Drive Read Speed 24x (CD) • 8x (DVD)
    Optical Drive Write Speed 8x (CD)
    Optical Drive ReWrite Speed 8x (CD-RW)
    Display
    Display Tech XGA TFT LCD
    Screen Size 14.1 in.
    Display Max. Resolution 1024 x 768
    Video
    Graphic Processor NVIDIA GeForce4 440 Go
    Graphic Bus Interface AGP x4
    External Video Resolution 1920 x 1200
    Audio
    Audio Output Type Headphones • Sound card • Speaker(s) • SPDIF out
    Audio Input Type Microphone
    Operating System
    Platform PC
    Technical Features
    Expandability 1 x Type I/II PC Card Slot, 1 x Memory Stick Card Slot
    Expansion Ports 2 x USB 2.0, 1 x IEEE 1394a (FireWire), VGA out, RJ-11 (modem), RJ-45 (NIC), S-Video out
    Input Method Keyboard • Scroll Button • Touchpad
    Networking
    Networking Type Integrated 10/100 Network Card • Integrated Wireless LAN
    Data Link Protocol Ethernet • Fast Ethernet • IEEE 802.11b • IEEE 802.11g
    Modem
    Modem Type Fax / Modem
    Analog Modulation Protocol ITU V.90
    Battery
    Battery Run Time 2.2 Hours
    Battery Technology Lithium ion
    Dimensions
    Width 31.5 cm
    Depth 25.9 cm
    Height 2.4 cm
    Weight 2 kg
11/4/2014 12:17:03 PM • Samsung X05... • Answered on Nov 04, 2014
Dvd rom in samsung laptop 300E failed to be recognized
boot live os cd if its ok problem in your os
4/29/2014 5:45:31 AM • Samsung X05... • Answered on Apr 29, 2014
0answers
Sound card driver
sound driver Samsung x05
11/18/2013 7:10:37 AM • Samsung X05... • Answered on Nov 18, 2013
Forgot pasword
Unless you are running Windows 8 and using an online account, you will have to restore Windows.
9/13/2013 12:29:29 PM • Samsung X05... • Answered on Sep 13, 2013
Audio controller driver
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers If your computer came with a motherboard disk the drivers could be on it or you might download slimdrivers. Rather doing a driver hunt http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 Note: it will find all of your outdated drivers This is a free driver solutions which will automatically search for and find the correct driver You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. It might take some time being free also http://download.cnet.com/2000-20_4.html Just type in what you want or need be specific you might have to try a few times to get it right. Tick in either the all software or the windows software box. IE: Motherboard name sound drivers
8/4/2013 9:31:34 PM • Samsung X05... • Answered on Aug 04, 2013
No audio sound
Make sure your speakers are not muted. Also, try plugging in headphones and checking for sound. If no sound plays through headphones or speakers, and sound is not muted, you may need to restart your computer. If that does not help your soundcard drivers may need updated.
8/4/2013 11:39:40 AM • Samsung X05... • Answered on Aug 04, 2013
Multimedia audio driver
3/18/2013 9:51:26 PM • Samsung X05... • Answered on Mar 18, 2013
3answers
Looking for drivers
Hello
The Link below leads you to download drivers for Samsung X05
http://www.samsungpc.com/products/x05/x05_supporteddrivers/x05_supporteddrivers.htm
Good Luck and do rate the solution
3/14/2013 9:33:28 PM • Samsung X05... • Answered on Mar 14, 2013
When i turn on my laptop it makes a ticking sound and then a black screen telling me to reboot
A ticking sound is usually a major indicator that your Hard Drive is / has gone out. I would look at replacing your Hard Drive. If it is a bad Hard Drive it would lock your system up bad enough to have to remove the battery to shut down the system.
1/18/2013 4:37:08 PM • Samsung X05... • Answered on Jan 18, 2013
I have lost my audio driver
insert the mother board cd run it select audio drivers install itrestart pc/laptopenjoy sound
6/5/2012 11:11:10 AM • Samsung X05... • Answered on Jun 05, 2012
Samsung X05 Notebook Logo
119 questions posted
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
X Samsung
  • X Samsung
Most Popular Question
ive lost connector between hdd samsung
  • Computers & Internet
