Hi, I have a Viewsonic PJ 588D projector, when I turn it on the lamp comes on for a few seconds then it goes of again. I have changed the lam and still experiencing the same issue. Can anyone help? Thanks. WK.
SOURCE: Lamp will not turn on.
If the ventilation fan is not spinning you will really have this problem, because if the fan is not working overheating problem will arise and will lead to this problen, so you will need first to replace the ventilation fan and that should fix this problem....
Hope that helps........
SOURCE: Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
SOURCE: Viewsonic projector Pro 8200 will not start / get out of standby mode
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Testimonial: "After I connect a power cord it starts blinking and blinks long time. These blinks timings look all the same. After pushing ON button it stops blinking, tries to do something and then blinks again and the same, with no difference with previous blinkings. Doe not seem it shows any codes."
