20 Most Recent ViewSonic PJ551 Multimedia Projector Questions & Answers
I have a viewsonic pjd5111
Unfortunately, the PJD5111 is indicating that the lamp has overheated. If you wait 45 minutes for the projector to cool down and these lights still come on, then the unit has an internal failure. The failure may be in the temperature sensor or that circuit. If the projector is still under warranty or on a maintenance plan, contact the dealer. I wish that I had better news for you. Cindy Wells
2/22/2018 11:44:13 PM • ViewSonic PJ551... • Answered on Feb 22, 2018
Won't focus
there is a adjuster on the lens, but it also depends on how fare you have it from the area you want to display too, as some are 3 meters or more away and some models are 2 meters away,if moving it to close to the area it displaying to and is clear at this point then the chamber has become moved (ie dropped or banged) this will knock out the alignment, and would think its the focuser has move. can also be condensation on the dlp if its been stored in a damp area this would also make it hard to focus as it would leave marks on the dlp chip that she light shines through. and would need cleaning off,
12/7/2017 12:58:54 AM • ViewSonic PJ551... • Answered on Dec 07, 2017
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
4/14/2017 3:47:07 PM • ViewSonic PJ551... • Answered on Apr 14, 2017
Lamp timer reset on my veiwsonic pj503d
hold the up button ( on the actual projector not the remote ) for 5 sec and then press auto
9/8/2015 4:38:00 AM • ViewSonic PJ551... • Answered on Sep 08, 2015
Reset button Viewsonic
MaYbe if your voice weren't so annoying you could ask a friend....hee hee hee
5/8/2012 5:02:48 AM • ViewSonic PJ551... • Answered on May 08, 2012
Where is the reset button on a viewsonic pj4200
HelloThere is a reset button on the remote control of this set. OK.
11/17/2011 4:46:01 PM • ViewSonic PJ551... • Answered on Nov 17, 2011
How do i access the air filter on the PJ551?
Air-Filter
Cleaning the Air Filter
The air filter should be cleaned as described below at intervals of approximately 100 hours. When
the filter is used for approximately 100 hours, the message "CLEAN THE AIR FILTER" appears
when the projector is switched on.
1 Switch the projector power supply OFF, and remove the power cord from the power outlet.
2 Clean the air filter with a vacuum cleaner.
3 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Please
refer to the description of the "FILTER TIME" on the Table 9: MAIN Menu.
Replacing the Air Filter
Replace the air filter if contamination cannot be removed, or if it is damaged. To order a new air
filter see page 26 for contact information.
1 Switch the projector power OFF, and remove the power cord from the power outlet.
2 Remove the filter cover and the filter.
3 Replace the new air-filter and the filter cover.
4 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Refer to
the description of the "FILTER TIME" on Table 9: MAIN Menu.
9/27/2011 10:40:23 PM • ViewSonic PJ551... • Answered on Sep 27, 2011
3answers
Not able to reset filter timer on ViewSonic
HI there
Scroll down to the filter timer in the Menu and hold down the right arrow button for a couple of seconds .
5/14/2011 3:58:39 PM • ViewSonic PJ551... • Answered on May 14, 2011
Ceiling mounted PJ551 - lamp light red, power light blinks red
I have PJ 550 exact SAME PROBLEM replaced bulb NOTHING
9/12/2010 2:55:24 AM • ViewSonic PJ551... • Answered on Sep 12, 2010
Viewsconic projector searching for source
try replaceing th e mainmotherboard
5/8/2010 11:59:34 AM • ViewSonic PJ551... • Answered on May 08, 2010
Projector Pj556d can find my hp computer
on the laptop,you will need to press the Fn key and then the f1,f2,f3 ect key until you find the display key,hold down fn and press the key untill you clone the screen
5/8/2010 11:59:04 AM • ViewSonic PJ551... • Answered on May 08, 2010
Replace old lamp but still get lamp fault
reset lamp timer
5/8/2010 11:57:39 AM • ViewSonic PJ551... • Answered on May 08, 2010
Screen projects a blue haze
chech vga cable
5/8/2010 11:57:20 AM • ViewSonic PJ551... • Answered on May 08, 2010
ViewSonic PJ551 Multimedia Projector Logo
46 questions posted
Top ViewSonic Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • ViewSonic Office Equipment & Supplies
Most Popular Question
not able reset filter timer viewsonic
  • Office Equipment & Supplies
