Changing the language from dutch to english
Just follow the instructions below
Instructions for Windows Vista
Click Start and then Control Panel
In Control Panel, if you are in Classic View, click on Control Panel Home (top left corner)
Open Clock, Language, and Region
Click on Regional and Language Options.
Click the Keyboards and Languages tab and then click Change keyboards.
Under Installed services, click Add.
In the Add Input Language dialog box, select the keyboard layout you would like to add from the list available and click OK.
The keyboard layout you added will be included in the list. To set the new layout as your default, select it from the list. Click OK to save your changes
You can switch between different input languages (= keyboard languages) by clicking on the Language Bar button or by pressing the Alt + Shift keys
Instructions for Windows XP
In Control Panel, if you are in Category View, click on Switch to Classic View (top left corner)
Open Regional and Language Options.
Click on the Languages tab.
Under Text services and input languages, click on the Details button.
In the Add Input Language dialog box, choose the input language and keyboard layout or Input Method Editor (IME) you want to add.
Click OK twice. You should now see a language indicator in the System Tray (located at bottom right hand corner of the desktop by default). You can switch between different input languages (= keyboard languages) by pressing the Alt + Shift keys
If a language does not appear in the Input language list, the fonts for that language might not be installed. If that is the case, follow the instructions below.
Add language support
Open Regional and Language Options in Control Panel.
