Computers & Internet Logo
A
Anonymous Posted on Sep 22, 2014
I have a emachines model t6524 and the wires that ture the power on in the front cam unpluged there are 6 red 7bk blu7bkbk7whit
I dont know were thay go
Matthew Spark
Level 3:
Genius:
  • Master 1,066 Answers
  • Posted on Jan 03, 2015
Matthew Spark
Master
Level 3:
Genius:
Answers
1066
Questions
Helped
298187
Points
2431
i have a emachines model t6524 and the wires that  - 25126336-cyh1nhlz3nmhmciytcwjnjrb-4-0.jpg 25126336-cyh1nhlz3nmhmciytcwjnjrb-4-1.gif
it will look something like the above. this motherboard is often used in your model
2 Related Answers
Anonymous
  • Posted on Sep 09, 2008
SOURCE: wiring info
Lay out is screened on the Motherboard above the Battery
HD Led pinss 1-3
Pwr Led pins 2-4
Reset pins 5-7
Power On pins 6-8
Anonymous
  • 16 Answers
  • Posted on Jan 20, 2009
SOURCE: Emachine model W2888, wiring
this is someone more suited for a trained technician, but you can look at the motherboard, where the pins were, and you should see markings like pwr +, pwr -, led +, led -, hdd_led, etc, you will also see markings on the cords that connect to the motherboard, with the same words, pwr+, pwr-, etc, you can try matching those up..
On my camera the wires have been cut and dont know were thay go model vf0410
wrong forum this is cars.
try web cams.
computers + web cams off fixya home page. pick this.
for 1000x better answers
http://www.fixya.com/troubleshoot/browse/web_cameras
"NTLDR IS COMPRESSED PRESS CTRL+ALT+DEL TO
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
Front power switch broken. Bezel won't come off easily. Thought we could just get a switch and install on the back but don't know which of the colored pairs of wires go to the original switch in the...
I would suggest this generic Power On switch,
1) http://www.directron.com/atxswitch.html,
and the Red, and Black twisted pair of wires go to the Power On switch.
Your statement of ,"....don't know which of the colored pairs of wires go.....", leads me to believe you may have all of the Front Panel wires disconnected.
How about information as to where ALL the Front Panel wires go?
(Provided I have correctly interpreted your statement)
Back in the time that the eMachines T2542 was made, TriGem was the motherboard manufacturer.
The Model Name of the motherboard is Imperial, and the Model Number of the motherboard, could have been one of four variations offered.
Model Name: Imperial
Model numbers could be G, GL, GV, or GLVE
(Imperial G, Imperial GL, Imperial GV, or Imperial GLVE)
ALL four variations used the same Front Panel header.
(The connector on the motherboard the Front Panel wires connect to, is named the Front Panel header)
I would like you to view this page,
http://www.e4allupgraders.info/dir1/ecase/support/front_panel_header_support.shtml
Scroll down to the heading -
Trigem Imperial Front Panel Header Pinout.
A) Pins 1, 2, and 3 are for the Power On LED light.
B) Pins 5 and 6 are for the HarDDrive activity LED light.
(Pin 4 is not used. NC. No Connection)
C) Pins 7 and 8 are for the Power On switch
D) I wouldn't connect any wires to Pins 9 and 10, nor Pins 11 and 12
E) Pins 14 and 15 are for the Reset switch. (The button you press to restart your computer.
If the T2542 doesn't have a Reset switch, don't worry about it. There are many other ways to restart your computer)
F) Pins 17 18, and 20 are for an internal speaker.
This speaker is used for BIOS Beep Codes.
In the chart to the right, you will see GRD used many times.
GRD stands for Ground.
ANY Black wire in the twisted pair of wires, is a Ground wire.
Most of the eMachines I have worked on, use a Red, and Black pair of twisted wires for the Power On switch.
I could be mistaken on the T2542.
Best method, is to follow the color code of the wires that come from Pins 7 and 8, and be sure.
2answers
Had to replace power switch on emachine computer need to know where wires go
You must check cable(small) one the (left or right) one hard drive, CD Drive, floppy disk and for motherboard (the big one) .You check the manuals, is not hard just follow where the power lines.
Unplugged power button from emachine t3624 forgot how to
If you can not see a "+" and "-" sigh on the connector as well as on the motherboard, then try it both ways. If you get it wrong the first time, it will not harm anything, just plug it in the other way if it does not work. Good luck!
Emachines T6524 has lost green color in monitor
this is a internal problem with the display. you need repair
System will not power on.
Hi Robert,
Have you checked to see that there is no cabling of any sort in your machine that may be brushing with the side panel when it is closed? I'm thinking maybe a GRND pin from either the front panel connectors or a USB connector but this is only a guess. I am unsure why a panel could stop it turning on! Let me know if its resolved! :o)
2answers
Wiring info
Most Mobo's have printing next to the places that are jumpered or pluged into. The ones you need sould be close to the edge of the mobo, that is close to the front {power button} side.
Power button wiring
A quick google determined your emachines model w2040 is equipped with FIC motherboard AM37. Download the manual from
http://www.fic.com.tw/support/motherboard/motherboard.aspx?model_id=107
You'll find the pinout info for your wiring on page 13.
Most motherboards also have the pinouts silkscreened onto the board itself.
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
