20 Most Recent eMachines E442 E442-v133 15.6" Notebook Amd V140 2.3ghz Cpu 2gb Ram 120gb Hdd W7 Questions & Answers
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
eMachines E442... | Answered on Dec 19, 2018
There is a button in ur keyboard for projector / TV press the button and your screen will come.
You may have to press the function key and that button together. That button usually stay with the F keys
eMachines E442... | Answered on Oct 31, 2014
You may need to hold down the "fn" key (near the windows logo key) while pressing F5 to get the function key to work as you want it to.
eMachines E442... | Answered on Aug 08, 2014
Click Start > Go to Store > Search there Drivers.
Hope I helped.
eMachines E442... | Answered on Oct 25, 2013
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. Usually a wifi enabled phone, computer, or whatever device, will recognize if there is wifi access near you. If not you may need to turn on the wifi on those devices. Usually those setting can be found in menus like Network Settings. Once it recognizes the network you will need the password if it is required. Just enter that in and you are set. Where you enter the password is usually in the same menu in which you turned on your wifi enabled device. if still no connection Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. Click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx
eMachines E442... | Answered on Feb 18, 2013
Make sure your installing the right windows either 32 or 64 bit windows.you can't install a 64 bit system on a 32 bit if it doesn't support it.
eMachines... | Answered on Oct 26, 2019
microsoft has a license type called OEM which detects the computer that it is installed on and some computers have the licence key stored in the bios of the computer.
So when you grab the old hard drive and put it in the next computer Windows will detect you changed computers and not run as per OEM licensing rules that it runs on only the original purchased computer.
You might be able to run the drive as a secondary drive but you would need to install a new windows operating system and hard drive. And then use a partioning program to make the secondary drive not an active drive.
also you new machine most likely has a different type of bios called EFI
and you would have to change its settings to run AMI Bios but I do not think that is your problem as I think it is OEM but it might be worth investigating if you can run a legacy bios in the bios settings.
eMachines... | Answered on Oct 05, 2019
Hi there. If your desktop has been overheating for any reason you will need to look at buying a new processor (cpu), power supply (if wires have been damaged from heat or voltage spike), or possibly a new motherboard. It would be advisable to have a computer shop look at the internal components of your desktop. Heat or a surge in power can damage the computer hardware. Good luck!
eMachines... | Answered on Apr 09, 2019
hello and good morning.
emachines are old and now owned by acer.com (gateway,etc)
they OWN many old names.
you are running XP right? the last man on earth to do so?
XP is a virus magnet and doomed, it is time to upgrade.
this PC is 2007 made. so is 12 years old, today..
the RTC coin cell battery will be no good now, replace it for $2
then reset BIOS inside BIOS screen " set default"
then test the HDD, to be sure it is ok, if not? then reloading any OS of any kinds is not going to work with any bad HDD.
Last, reload a new OS.
there are the steps. and can be expensive, spent on any PC this old with zero street value. ($0 if broken a it is)
eMachines... | Answered on Apr 01, 2019
http://www.emachines.com/ec/en/US/content/drivers.html
eMachines... | Answered on Mar 02, 2019
Examine the rear panel carefully to find it.
eMachines... | Answered on Feb 02, 2019
You'll have to unsolder the entire battery holder and replace it with a new one. Not suggesting you try it unless you have the proper desoldering equipment. Otherwise, damage to the motherboard will result
eMachines... | Answered on Nov 04, 2018
eMachines E442 E442-v133 15.6" Notebook Amd V140 2.3ghz Cpu 2gb Ram 120gb Hdd W7 Logo
9 questions posted
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • eMachines Computers & Internet
Most Popular Question
drivers download
  • Computers & Internet
