Just tried using the xd picture card for the first time. It fits perfectly into the slot but does not click into place as it is supposed to. Camera will not record images on the card.
Are you sure it is a xD card and not an SDXC?
Then there should be a little arrow, pointing in the direction it should be going while inserting.
Try to eject the card and reinsert the card.
If you never used a xD card, and nobody else ever tried to put something in the slot, the card should go in smooth.
After placing the card, don't forget to format the card in the camera.
I'm sure it is the right card and it goes smoothly intot he slot provided. Problem is that it does not click intoplace but just fita loosely. Error message has disappeared but I did format it then took several pictures but when I try to access the file on my computer it indicates that there are no images in the file.
New memory card won't click into place - any ideas?
SOURCE: Olympus 2G xd M card with pictures - error message "clean card" or format
Just had the same issue today. The Olympus Helpdesk told me that the fact I had printed one of the picture from the Xd card in directly inserting the card in the printer slot for Xd created the problem....
The guy from the Helpdesk strongly recommended to transfer the pictures from the camera to the computer exclusively using the USB cable of the camera.
In the end I have saved all my 505 pictures in using the Smart Recovery from PC Inspector but why the hell this problem only happens with Xd cards?
SOURCE: clean or format card error on Olympus XD card
There are most likely some "corrupted" images on your xD card. Very often a card reader "writes" data to the card while transferring or copying images into the computer. When you re-insert the card back into the camera, it doesn't recognize the new data (because it didn't create it), and gives the error, usually requiring a complete formatting be performed. There are also problems if you use a reader to rotate images, then re-install the card in the camera. The best way to accomplish what you were doing is to transfer the images into a folder on your computer, as the camera shot them (don't rotate them first). That way, you haven't altered any data on the card. For now, however, I suggest you format the card in the camera, so you can start with a "clean slate". Good luck.
