I noticed that my dehumidifier had stopped working and went to empty the water as usual, but there was very little water. I then noticed the humidity level was set to 85% - the maximum it can be. I tried to set it lower, but the unit immediately began raising the level until it stopped at 85%. I unplugged the unit and tried to "reset" it and it still does the same thing. There are no error codes and it still works as long as the humidity is above 85%. Is there anything that can be done to fix it or is it just toast now?
Hey Art Miner, thank you for your post!
I understand that your dehumidifier is not operating properly. You should put it on a continuous drain mode to see if it will continue to pull moisture. Could you please provide feedback to what your appliance is doing once set to a continuous drain? -Matt
Testimonial: "Thank You Matt, I tried to put it on continuous drain mode, but when I plugged it in again none of the control panel buttons would respond - not even the power button. I'm afraid the control board has died. I can't do anything with it now. It started running, but I couldn't set it at all. I appreciate the help, but I think it needs a repair shop at this point."
I appreciate your post, Lee Silvey!
I understand that your Frigidaire dehumidifier, FDL70S1, will only work in continuous mode. Sounds like you could have a possible issue with the sensor or control panel. Are you under warranty? I would advise you to speak with your manufacturer to see if any further resolution can be provided. -Matt
