SOURCE: I have a lexmark x4550. replaced the color
your color cartridge is damage change it and insert niw cartridge
SOURCE: SAys replace ink cartridges.. did that but still
The problem sometimes is that when you unpack the cartridges a little bit of residue of the packaging stays in the printhead of the cartridges. Here is a link that shows you how to clean the nozzles. http://www.bit.ly/aBjxGa
SOURCE: how to reset ink cartridge for lexmark x5650 #36
Take a small pice of clear tape. Try covering one of the outside vertical row of contacts at thr front of the cartridge. Re-insert it and it shoudl "fool" the printer into thinking it is a new cartridge. It works for my Lexmark 2600 series all in one
SOURCE: We have a X5650 Lexmark printer. The ink
It could be that the cartridges are not inserted properly in the carrier or just needs cleaning. Try to remove both cartridges from the printer and manually clean the nozzles. You may refer to this article on How to Clean the Print Cartridge Nozzles and Contacts Manually. Then reinsert one cartridge first and close the cover. If no error appears, reinsert the other cartridge. Replace whichever cartridge is causing the error. You can also try the Clean Cartridge function on the printer by pressing the Setup button -> Maintenance -> Clean Cartridges. It will then print the clean nozzles test page. If error continues, replace the faulty cartridge.
