On the display, it gives the extension, but I want date and time on
Just press on ( * )
haha it was that simple?
thanks i made it
thanks to you. this the only answer i need.
Ha! That was easy. Thank you!
SOURCE: Panasonic KX-T7456 Corded Phone - Date & Time Display
The display on the phone ... to change back and forth between the date and time,
and the extension information, press the "star" (or asterisk) key while
the phone is on-hook, this will toggle the display back and forth.
Hope this helps, David B.
SOURCE: Panasonic KX-T7730 Corded - change display
On mine I press the asterix to toggle display options
SOURCE: Panasonic KX-T7730 Diverting Calls back
If you set call forward all calls then lift your handset press the FWD/DND button, dial 0 , you should get a tone, then hang up. If you set Follow Me then dial 8 and your extension number instead of the 0 . Good Luck. ....Mike
SOURCE: Changing the names for extensions
Name changes are done from the System Administrators phone. In the TA-series, it's system program 604. In a TAW it's 004. I can give you complete instructions, but you have to get to that screen first.
If you get there and want to play, the SP Phone FWD CONF MUTE and keypad press up to 7 times enter the Alphabet names (space is under 1). Nothing writes until you press STORE.
Carl
SOURCE: KX-T7730 Time and Date
Walk up to the phone and don't touch anything but the * button. Keep pressing it and watch the display. Now you now the 3 states of the button.
Carl
