Press the last channel view button if you did that only the once, it should go back to the channel it was on prior to the "accident channel". I hope this helps, Jesus loves you, John 3:16-17 (KJV)
I have exactly the same problem, same error message. I first noticed the problem yesterday (September 11). Error message appears when trying to watch live TV through iPlayer. BBC News Channel works OK from BBC News website. Live sports broadcasts work OK through BBC Sport website. I uninstalled and reinstalled Flash Player but it made no difference.
What service company do you have for your TV? Is it dish network or direct tv etc. You can do a channel scan once you verify the service company. A cable service provider will only provide 99 channel to scan/sort while a satellite service provider will provide you more channels to sort/scan.
Direct Dish.... :p only outputs to your TV on channel 3 or 4. This leads to only using Direct's remote. I would suggest to try going over to DISH Network as their remote is much better and will work the TV......
first of all, make sure all your connections are secure and threaded all the way in. Next, go to the main menu and press 5 (configuration) and press 1 (search for channels) if this doesn't work, press 4(signal strength meter) and see how strong your signal is. You may just need to re-position your antennae. If all else fails try system reset(number 5) and repeat search for channels. I've had similiar experiences with mine but I have a 62% signal strength and still get 20-something channels. Hope this helps.
Connect your Direct TV to the Ant. In connection on your VCR. When you want to watch TV, just tune the TV to channel 3 (or whatever channel the Receiver is set for). When you wish to record, set your VCR to that same channel and set your TV to the channel that your VCR outputs to. For simplicity sake, I would suggest setting both systems to channel 3 and just watching your program through the VCR. If you are still using an "off air" antenna, then connect that antenna to the ANT. IN connection on your Direct TV receiver and when you turn off the dish, it will pass the signal through just like the VCR would.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6.
it is due to cable signal ie weak.
now there is no sound
this is due to sound section
1 loose connect in sound section
2 speaker
3 problem in sound section some part must have failed.
