Bernina Artista 640E Sewing, Quilting and Embroidery Machine with Embroidery Module Logo
A
Anonymous Posted on Aug 21, 2014
Why does machine sew then stop after maybe 8 or 10 stitches?
This happens over and over and has always been a problem with this machine and it does it whether in straight stitch mode, decorative mode or when using BSR. It does this half a dozen times, then will sew 30 or stithes, then begins same cycle again. Have had it in the shop for cleaning and tech doesn't seem to find the problem. Also inconsistent when doing decorative stitching. I CANNOT figure out what problem is and it's so frustrating because I like the machine in so many other ways. I expected better from Bernina! Also getting decorative stitch to repeat numerous times doesn't seem possible, have to keep pressing the escape feature to continue. What am I doing wrong for set-up? The manual is no help.
Ruth summersides
Level 3:
Genius:
  • Bernina Master 1,493 Answers
  • Posted on Nov 26, 2014
Ruth summersides
Bernina Master
Level 3:
Genius:
Answers
1493
Questions
Helped
363485
Points
2425
You obviously have a faulty machine take it back to your dealer where you bought or directly contact Bernina.
Best wishes.
5 Related Answers
RickE1
Rick
  • 202 Answers
  • Posted on Feb 13, 2009
SOURCE: Bernina 830 won't zig zag, won't buttonhole, no decorative stitch
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps, I know it will.
RickE1
Rick
  • 202 Answers
  • Posted on Jul 24, 2008
SOURCE: my bernina sewing machine won't
Sounds like its skipping stitches. The very first thing to do is put in a new needle. A dull needle will cause this for sure.
After that it may take a tech to make some adjustments.
1) The hook is slightly out of time. On this type mechanism, there is
a slight difference in timing for the different needle positions.
2) The needle bar is slightly too high.
3) The hook and needle are too far apart, and then the skipping would
be more apt to show up on light weight fabrics.
Anonymous
  • 6 Answers
  • Posted on Apr 11, 2009
SOURCE: Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
berninafan
  • Posted on Jun 17, 2009
SOURCE: Bernina Aurora 440 knotting below my fabric and into bobbin area.
Are you sure you have the bobbin the right way round in the holder....when you look at the bobbin and tug the thread, the bobbin should move clockwise.
Pull out the foot pedal and use bsr2 with the start/stop button.
Bring bobbin thread to top of work before starting to sew. This may help knotting problem
Anonymous
  • 55 Answers
  • Posted on Jul 27, 2009
SOURCE: bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
scott
Machine sews 5 stitches stops, sews another 5 stitches, stops?
What happens when it stops? Do you get an error message? Does it say that it's out of thread? Are you doing embroidery, or sewing at the time?
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
1helpful
I have a Hyundai 8 stitch sewing machine and have great difficulty sewing with it. The thread keeps bunching up underneath and misses a lot of stitches. I have followed instructions, both threading up
here is a suggestion for the skipped stitches
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
and since it stops with a crunch,, I suggest having the machine
checked to see why that happening
I have a brother VX-950 sewing machine I have a pretty good stitch on top and bottom, put it is still puckering. I tried the tension. What elese should I try?
New needle and make sure it is the right sized needle for the fabric that you are sewing. If silky satin then use a size 70 or even 60 needle sharp. If microfibre then there are Schmetz needles called microtec that are perfect for this.
Also try shortening the stitch length a little. You may still need to finesse the tension a bit. I think this is a front loading bobbin machine so you might try adjusting the tension on the bobbin holder a little bit. It is hard with these as there is no "0' marking to set it to, its just trial and testing.
Also, are you pinning across the seam line at about 3 inch intervals?
If there is still some puckering happening, then perhaps, stop at the end of the seam with the needle in the work, and ease the fabric along the stitching line a bit to smooth out the seam, then do the reversing stitches at the end to lock off the seam.
Also press, press, press each seam. Always press on top of the seam, turn it over and press the underside of the seam, then lie right side down on the ironing board and press the seam allowances open. This sets the stitches into the fabric and finishes off the seam appearance. I always sew with the ironing press on beside me.
You may still be unhappy with the seam result after doing all this - if you enjoy sewing then consider shopping for a higher quality machine - there is a difference in stitching quality between a $400 and $2,000 machine. You could always take a piece of your fabric to a sewing dealer near you and test sew on a European machine, you should see a difference in the stitching quality.
I have a Kenmore sewing machine Model 158.17030. It's an older model and I don't have the user manual. I can't figure out how to set it on the hemming stitch. No matter what I do, it just sews a straight...
Hi. First, I'd recommend you get a replacement manual. They are really useful. Check out http://sewingpartsonline.com/sewing-machine-instruction-manuals.aspx.
I assume you have different stitches on the machine and a diagram of some sort showing what each stitch looks like. Find one that looks like:
---^---^---^--- (maybe on its side). That's the blindstitch. Some machines require you use a blindstitch foot with the stitch, but some don't. Without the user's manual, it's hard to say what your machine requires.
Good luck and let me know what happens.
Robbie
Not feeding.
Check to see if the feed dogs are up, maybe you somehow clicked or switched a button, it happens to me some time when I take the bobbin out and put a new one in. I don't know your machine but some machines have the lever/knob for dropping the feed dogs in a strange location.
6helpful
2answers
Machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
1helpful
Machine sews zigzag although stitch is set at 0 for straight
It must be a design flaw- things don't always last like they are supposed to. I would personally check the physical reason it is not responding... knowing what it would take to make it stop moving- or whatis causing it to. *perhaps the switch isn't working to stop it- or the mechanism that controls it is worn down. If it was new- I'd return it- but there are only a few options at this point.
Sewing Machine Stops
this sounds like its set for zippers check settings!
Top Bernina Sewing Machines Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
