Dyson DC59 bad smell from filter
Forget it. Unless you dislodge all of the tacky dust from the cyclone cones it will ALWAYS smell. Tumble dryer sheets cover the smell for a week at best. The oils from dog fur are attached to minute rasps of cracked hair which forms dust. This is what stinks and attaches to ALL inside workings of the vacuum and those you cannot get to without a knowledge of dyson and torx screwdrivers.
We have had several Dysons, they are great vacuums but should not be marketed for animals. The nature of a bagless vacuum means this smell will occur. As Dyson have moved away from filters altogether in some of their later ranges, they are even more prone to this collecting of dog stench. Cleaning filters as Dyson suggest is nonsense.
Using the the dyer sheet method works like a charm. Thank you!
You can't wash all the stink out of filters. They should be replaced frequently. After repairing vacuums for 30 years I'll take a bag over bagless.
Hi there, it's Jack at Dyson.
As you'll probably be aware, DC59 has one washable filter, engineered to last the lifetime of the vacuum. We recommend washing this at least once a month using cold water without detergent, as shown in the video below:
Always allow the filter to dry completely before replacing it - this may take at least 24 hours. Replacing the filter when damp could cause damage to the machine not covered under guarantee, and could also contribute to any odour coming from the vacuum. It may help to place the filter somewhere warm to dry, such as by a radiator, in an airing cupboard or on a sunny window sill.
Please note, the cyclone pack and clear bin should never be washed or submerged in water as this could cause permanent damage to the vacuum. However, it is possible to separate the clear bin from the cyclone pack as shown below. You can then use a soft brush to remove any fluff or debris from the mesh shroud, and you can wipe the inside of the clear bin with a damp cloth to remove any clinging dust particles. Make sure the bin is completely dry before reassembling.
I hope this helps, but if you'd like any further advice on cleaning or maintaining your DC59, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
SOURCE: My Dyson smells like a
I have the Dyson DC 28. After cleaning out the filter multiple times I still had the wet dog smell coming out from the vacuum. I called Dyson's support line. The rep told me to put dryer sheets in the clear plastic bin and let it run for about 5-10 mins, make sure the bin is clear of all debris first. I did it and it worked. Not only is the smell gone, the dryer sheets removed all the remaining dust stuck in the bin. I was happy!
SOURCE: OUR DYSON DC 17 ANIMAL HAS A SMELL OF ABOUT 50
Try buying "Citronella" from an essential oils dealer (maybe eBay?) Apply 6-12 drops on the paper filter element...you'll LOVE the smell.
P.S.
Haven't you asked this question before?
SOURCE: Dyson makes smell
You need to replace the belts. When they are worn they put off a smell. Here is the belt you need:
Dyson DC14 Belt
SOURCE: hi how can i clean
The course of action we'd recommend would depend on the model of Dyson cleaner you own, which you haven't specified in your question. It's probably best if you get in touch with us directly so one of our experts can determine which model you have, and run through some troubleshooting checks with you over the phone. If you're based in the UK, you can call us free on 08002980298. If you're based in the US, you can call free on 1866MYDYSON. We look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
