It sounds like your machine needs either the shifter calibrated or replaced. It doesn't seem like any non electric portions of the shifter are broken or you wouldn't be able switch between gears. You might want to have a technician use a multimeter to find out if any shifter-related wires have stopped working. You can also reference the troubleshooting section of your manual for another perspective.
I have seen a number of domestic rotavators but haven't yet seen one with a reverse gear. You didn't make it clear in your description whether yours has a reverse gear and that is all that is working or whether it usually only moves forward but is moving backwards?
While it is theoretically possible for a 2-stroke engine to run backwards, your engine is a 4-stroke that is incapable of running backwards and so it would seem the gear selector is stuck if it has one or someone has carried out repair work and made a mistake or something else is broken.
The only thing that comes to mind is some of the older designs used an over-long drive belt that crossed in the middle like a figure eight in order to reverse the driven pulley and replaced the belt with one that seemed the right size would cause the machine to run backwards.
If it is an automatic, and absoloutely no movement it sounds like the torque convertor has failed. Either impellor or turbine. If it is a manual the clutch may have gone. If it is a manual, place it in gear and get a friend to rock the car back and forward. See if you notice any movement of the harmonic balancer/belts in the engine bay?
