Toner & developer is changed but light is blinking and motor does not run normaly when you start for the first time
Motor temperature rise too high or smoke fault:
1, the load is too heavy or too frequently started -- reduce the load, reduce the number of starts;
2, the lack of phase in the process of operation -- check the line, restore the three-phase;
3, stator winding wiring error -- check wiring, to correct;
4, stator winding is grounded, short circuit occurs between turns or phases -- find out the ground or short circuit parts, to repair;
5, the winding of the winding rotor phase - find out the fault point, to repair.
Motor vibration is too large fault:
1. Rotor imbalance -- leveling balance;
2. Unbalance of pulley or shaft bending -- check and correct;
3. The motor is not aligned with the load axis -- check and adjust the axis of the unit.
Click here read more details.
What motor are you talking about the fuser motor, paper draw motor, the finisher motor, the transfer motor, the drum motor, the developer motor, corona wire transfer cleaning motor. I can go on.
Replacing developer and toner has nothing to do with the motor running,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: toner light flashing, won't copy
Definately check and see if you are getting the motor current from the motor driver board and main pcb, before buying it. That should do the trick
SOURCE: SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
SOURCE: I have a sharp AR 5516 I am getting error F240, I
you are check and fix connection between toner cartridge and mcu pwb
