Remote Control Code for Element LCD TV -- & Direct TV Haven't been able to find the right code to program the - Olevia LT32HVM 32 in. ... It is annoying to turn the TV on and the volume with the Element remote and then have to use the ..... Need the codefor a 42 inch LCD TV model ELDTW422 to program our Direct TV ...
? 6:40
https://www.youtube.com/watch?v=EKtjBnx6EG0
Mar 27, 2013 - Uploaded by PureLegit
This is a new video on this TV that I got from Element. If you go back on my channel you will see my first ...
0038,0033,0031,0038,0036,0030. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
0048,0042,0041. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Check these codes. 0382,0825,0182,0492,0000. If you wish to get more setup codes, three
digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to
some popular model remote controls are given.
Setup code for Emerson TV/DVD combo is: 0456 Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then
release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator
blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry,
the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further
programming is required. Note: If some buttons do not operate your device, try
one of the other codes for your brand.
I just checked online at DirecTV and searched your Astar TV. This is the result I got...
"There is no setup code indicated for your product.
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
Set the "Mode Switch" to the desired mode such as TV for a Television.
Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
Enter the code "991" followed by the "device number"
for Televisions
for "AUX 1" devices - VCRs or DVDs
for "AUX 2" devices - Audio
You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
You can try out each code by pressing one or more function keys such as power, volume or digit keys.
When you've found the setup code that works for your device, press the "Select" key. "
I have an Acer 3720A and Shaw's Atlas PVR remote. I used the "scan feature" to find that code "0704" worked for me (at least for power and volume - which are all I need).
Whether or not this works for you depends on the specific Acer TV you have and possibly the model of "shaw" remote. Many Shaw remotes actually come from Universal Electronics (www.urcsupport.com) and they do not have Acer TV's in their DB. Acer's own site indicates they cannot provide a specific code (at least for my model of TV) and to try the remote's scan feature - which is how I ended up with my solution.
