Heating & Cooling Logo
Pin Ups Posted on Aug 02, 2014
ACEXC186E stuck in timer mode how do I reset control panel?
The Vamp
Level 1:
New Friend:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Aug 02, 2014
The Vamp
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
19
Questions
0
Helped
2892
Points
28
What version of Windows are you using ? You need to post this info for someone to understand what you are asking. Do you mean your computer goes to sleep ?
3answers
Hot Tub STUCK in Sleep Mode!
You should look at control panel, they are readily available on line for $160.00
Feb 05, 2022 • Pool & Spa
My Sony TV, trinton, is on stand by/timer mode. How can I get it off, so I can watch tv
When you turn off the TV and turn it on again, [Sleep Timer] is reset to [Off].
Setting the sleep timer
If it is stuck in standby mode and you are seeing a blinking light, welcome to the world of diagnostic codes.
Sony TV stuck in standby mode
1helpful
My Maytag MTB2156DEB fridge died. Electricity is on, lights are on but nobody home, I.E., no cooling. my old fridge had a "reset" button which I found out after the repairman charged a bundle to press. ...
Your model doesn't have a reset button, this is non-electronic. First, tap on control panel to see if cold control is stuck. (tap on beat) If it starts it could be a bad control. Does to compressor click like it wants to start? Lastly, there is a defrost timer within the control housing, with a screwdriver rotate the timer slowly to see if the timer is stuck. If the unit starts running it could be that the timer needs to be replaced. Get back to me and I can help further if needed. Good Luck
Iā€™m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
My freezer is not working its defrosting everything. Is there a reset or something I can do to fix it?
No reset button . Having no model number I gotta guess your timer is stuck in defrost. You must find the timer and advance it into the RUN mode. If the timer is good I would next take a look at the relay on the compressor. They fall apart overtime:
If this is one of the fancier ice boxes with auto defrost mess
then your thermistors could be bad or control board gone south. More Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
Defrost is stuck in one all time it not cooling or freezing
A DEFROST TIMER is a cycling device, it times the frequency and duration that the defrost heater coils melt the ice that builds up around the evaporator coils. If ice is allowed to build up, air will not be able to freely flow past them - resulting in reduced efficiency and sometimes a drastic warming of the cooling unit.
Most of the time, the defrost timer is in the cooling mode, allowing the compressor to activate when the thermostat signals it to. The remaining part of the cycle (usually less than 30 minutes)the timer is in defrost mode. In this mode, it signals the defrost heaters to melt the ice build up on the coils. This defrost action is limited by the defrost thermostat. If your DETROST TIMER go to bad, one symptom would be if your refrigerator is not cooling. Although there are many causes of this symptom, A stuck defrost timer can be one of them. The timer can get stuck in cooling (compressor activated) or defrost mode (defrost heaters activated) for usually two reasons:
- The timer motor can fail for one.
- The gears can also become locked up.
No matter what the reason is or which mode the defrost timer gets stuck in, the refrigerator can stop cooling. When the refrigerator is stuck in defrost mode, the compressor no longer comes on to cool the unit. If the timer gets stuck in cooling mode, the evaporator coils never get a chance to defrost, causing ice build-up to the point where there is a complete blockage of airflow past the coils.
The defrost timer can also cause the refrigerator to stop cooling due to failure of the internal switch which activates either the compressor or heater coils. Finally, when doing any repair on a refrigerator, check the condenser coils for dust buildup and clean accordingly.
According woth yur brand and model, look the part replacement in this link: partselect.com/refrigerator+test-defrost-timer+repair.
Good luck.
1helpful
HOW DO I RESET THE LAMP TIMER ON A SONY KDF55WF655
Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
1helpful
The unit won't turn on or off. I've changed the battery but still no response. also the reset button is stuck and won't work
A stuck reset switch keeps the timer in a rest mode so that nothing else will function. Try to operate the switch so as to free it. Then reprogram the timer if you are successful.
4helpful
Control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
1helpful
GE Profile PFSF5 NJWA BB
There is a timer that determines the defrost of the cooling coil inside the back wall of the freezer. defrost timer may be located in the area of the controls for temperature. Look for a hole in that area and recessed in that hole you may find a clutch head screw. Turn this screw clockwise very SLOWLY until you hear one click. The freezer coil will be in the defrost mode for 18-22 minutes and then the refrigerator should return to the cooling mode. Make sure the condenser is clean and free of dust and dirt. Condenser is where the heat is removed from the refrigeration system and on most models it is located in back behind a removable panel. Reinstall the panel after cleaning the condenser.
View timer is stuck on
take your set to a tech your problem is more a technical problem that sounds as you are having a chip problem that controls the timer
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
