Making master & slave to copy data from one to another
I don't understand your question but will give it a go.
You usually have more than 1 sata connection on the board. If only one is working or you only do have one connection. You can get a pci card that gives you extra sata ports ( http://www.ebay.co.uk/itm/like/261083138351?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108)
When setting master and slave this is done through the bios. An easier solution for copying from hard drive to hard drive ( much quicker) http://www.pcworld.com/article/2036718/why-its-a-good-idea-to-own-a-usb-to-sata-adapter.html
SOURCE: Two Maxtor hard drives -
Essential you have one license allowed and it checks the primary HD via its 'utilities function', and only does a general scan of slave. Since you did not mention Norton version nor your OS general assist here. You might consider going into Options and having it scan both HDs, worked for me.
SOURCE: HP d530 PC - SATA Harddisk - Chassis does not close any more
Martin,
They make SATA cables with a 90 degree connection on one end.
Hopefully this will solve your clearance problems with your case.
Here is a link to website that carries these.
Website Link
They work great and fit tight against the drive.
Hope this helps,
Eric
SOURCE: Does the dell dimension 3000 pc have sata data and
As marcor494 suggests, that's your best choice. But, what do you want to use the SATA HDD for?. If you are planning on having it as a primary partition HD then go with a pci sata controller, otherwise if it is intended as an extended partition i would suggest an external enclosure with usb/sata/firewire connectors (just in case you ever upgrade your desktop). Good luck.
