20 Most Recent Maxtor Hard Drive Questions & Answers
I have a 1000GB Maxtor Basics external drive. In
Power Supply: 12V 2Amps, + inside.
STM310005EHD301-RK external hard drive power supply
Here is a picture as well.
Hope this helps!
10/26/2021 10:57:31 PM • Maxtor Hard... • Answered on Oct 26, 2021
0answers
Maxtor one touch 4 mini 250 GB
try plugging it in and then clicking on it in the computer section right click on the properties tab and then click on compatibility click in the tick box and highlight win xp apply and ok do not throw ii in the the bin as it can be used as a hard drive in any computer or being mini , in any laptop unit
3/22/2017 1:19:04 AM • Maxtor Hard... • Answered on Mar 22, 2017
THE COMOUTER READS NO OPERATING SYSTEM I INSTALL IT WITH NO OS THE COMPUTER READS THE DRIVE BUT I CAN NOT INSTALL AN OPERATING SYSTEM
  • You should have an operating system install disk (or USB drive.)
  • Restart the computer and press whatever key gets you into Startup (typically F2 or Del.) You *may* have an option that says "Boot menu" that has another key (such as F12.) If you have that, use it.
  • Find something in your BIOS that mentions "Boot order" or "Boot priority."
  • If you have a CD, make your CD the first boot device. If you're booting from USB, make it your first device.
  • Make sure your install media is in the computer, save and exit.
  • The computer should now boot from the install drive and put the operating system on the hard drive.
3/25/2016 4:38:20 AM • Maxtor Hard... • Answered on Mar 25, 2016
2answers
Got virus cant open windows
install new os
7/28/2015 10:26:16 AM • Maxtor Hard... • Answered on Jul 28, 2015
2answers
I want to add another hard drive and need to know
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
5/14/2015 7:41:52 AM • Maxtor Hard... • Answered on May 14, 2015
2answers
WHAT POWER SUPPLY DOES IT NEED
Your PC PS will supply both 12 and 5 volt voltages to your drive via the connectors designed to power the peripheral..
4/19/2015 3:14:43 AM • Maxtor Hard... • Answered on Apr 19, 2015
How do i install maxtor diamond max 11
general you need to format the HHD - set it to active then give it a drive letter.
2/7/2015 8:53:56 PM • Maxtor Hard... • Answered on Feb 07, 2015
My MAXTOR Personal Storage 3200 says Read Only and does not allow me to write anything on it. It has never been used, only once to create two back-up files foe my wife and I, and they are empty but i
right click open properties, under security and make sure you have FULL ACCESS. and some time the BACKUP Program locks HDDs and you have to open with that program
2/7/2015 8:21:46 PM • Maxtor Hard... • Answered on Feb 07, 2015
2answers
Hp hard drives
You can put the defective HDD in a computer thats running correctly and use the existing OS to gain access to it. That way you can extract all the info from it. Do not remove the main HDD, simply shut down the PC, open it, add the Hard Disk Drive to the MOBO and restart. you may get an option to decide which HDD you want to boot from, make sure you boot from the good one. Make a file and extract all info. If the new computer does not recognize the drive, there are steps you can take to find it. I've done this hundreds of times and have had around 87% success. Unfortunately, some HDD's are destroyed and no data can be extracted. Good Luck
12/7/2014 4:23:47 AM • Maxtor Hard... • Answered on Dec 07, 2014
750gb
3.5drives require 12vdc at no less than 2 amp recomended 12vdc 3amp it is always best to provide more amp for hard drive keep the voltage correct 12vdc asme adaptors work out to 4 gig drives all my Western digital drive have same power adaptor no matter the Gig size .
11/26/2014 12:32:02 AM • Maxtor Hard... • Answered on Nov 26, 2014
2answers
Need a power supply for mr Maxtor Hard Drive 120 GB SN Y3LCM1EE 12v & 3 Amp.
Go to tiger direct or new egg for the best prices. Make sure that the power ratings on the new one is the same or higher than the old one.
11/26/2014 12:21:40 AM • Maxtor Hard... • Answered on Nov 26, 2014
What size Torx Screw-driver is needed to Take
Maxtor drives use a T8.
6/18/2014 3:42:24 PM • Maxtor Hard... • Answered on Jun 18, 2014
805 questions posted
Top Maxtor Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Maxtor Computers & Internet
Most Popular Question
comouter reads no operating system
  • Computers & Internet
