I'm trying my password, but its not working. I think my caps lock is on, but I can't tell. There 3 locks on top the 1st one is lit up but the other 2 are not.
SOURCE: power light comes on -
Can be one of three things:
Power not adequate enough for laptop - You can purchase a new power adapter relatively cheap from eBay for around $10.00. It may have been surged and will not allow the battery to charge or allow enough power to start the computer.
Bad battery - Take the battery out of the laptop and try it without. if it works, replace the battery or use without it.
Bad screen (inverter) - The inverter can be damaged. This can be caused by wear and tear, being dropped or other. The inverter is like a lamp that sits behind the screen. Take a flash light and place it directly into the screen to see if there is indeed a picture back there (will be very dim). If so, replace the inverter (difficult) or replace the screen (simple). Easier diagnosis would be to connect another monitor and see if it comes on (instead of the flashlight method).
SOURCE: When I turn the dell d610 caps lock led flashes and then goes off
Try reseating the RAM module(s) then see if the issue goes away. If no change, try them one at a time.
SOURCE: dell inspiron 1501, caps lock and scroll lock
i cant if my mute botton it all was say mute of and i cant hear anything
SOURCE: Dell Studio 1737 with Back lit keyboard but Cap Lock Doesn't Light
Dear Janice,
The light under the Caps key must have burned out. Take your laptop to a Dell service center and get it repaired.
