I can only watch G-rated DVDs due to parental controls. I want to either change the parental rating or at least have the password to change settings on the player. Where is the password and if I cannot find it, can I take the memory chip out and burn it to something on a chip burner? Help?
Http://www.dvddemystifiziert.de/codefree_en/coby.html
Unfortunately, I don't see Coby 206. There is a 207 however if that would work.
Unlock Coby DVD players - DVD hack
Coby DVD-201 / DVD-217 / DVD-224 / DVD-227 / DVD-237 / DVD-505 / DVD-514 / DVD-527
Coby DVD-202 / DVD-203 / DVD-207 / DVD-208 / DVD-218 / DVD-507 / DVD-508 / DVD-606 / DVD-615
SOURCE: coby dvd-224 "loading"
If everything else seems to be functioning, try using your remote to reset the TV. There is a setting to switch the TV from being a TV to being a screen, or monitor, for the DVD player. What the button is labeled varies by manufacturer. It may be: TV/DVD, input, source, display, or something else. Display, for instance, displays the choice on the screen. Highlight and select DVD or perhaps the brand name of the DVD player.
This compliments of the Vancouver Radio Shack super geeks.
SOURCE: Parent control lock
The parent control lock out code is 1234, you need to press yes then enter the code using the remote type in 1234 then press play button again and it unlocks the parent controls!
SOURCE: coby 7100
With no disc in player:
On remote control:
Press Setup
Press FF
Press FR
Press Next-Chapter
Press Prev-Chapter
(Current region shown on screen)
Push right arrow to increment 2.. 7.. 255
(When number = 255, Press Enter)
Press Setup to finish
SOURCE: wrong disc error
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately,
if
the player will no longer read any commercial dvd that you attempt to
play, the unit is defective and needs to be replaced. The unit has a 90 day warranty from
the date of purchase. You will need the receipt in order to receive a
warranty exchange.
If
you feel this solution doesn't deserve a good rating, please let me
know why so that I may better assist you. If there is anything more I
can do to help, I will!
SOURCE: I reset the factory settings
Did you use the reset instructions that are found on a sticker on the top of the player? If so, and the unit is still asking for a password, this might mean the V-Chip or parental guardian has been activated. Please call the customer service number above so see if there is a master password available.
If
