20 Most Recent
Coby TV Remote Control Questions & Answers
I need to have a new remote control for my television coby
093,028,082,073,000,019 are the codes to check with Coby brand TVs. If you wish to get more details, check
this site.
Pull up previous posts there. Setup code list and setup proceedings to
many popular brand remote controls are given.
Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device
into its search box, and press "Enter"
Where can I buy a remote control for a labgrearHDSFC2
Try this link.
www.Alibaba.com
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device
. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
http://electrohelponline.blogspot.com/
Change batteries still not working. No button is
ok try this tip very carefully open this unit up and clean the silver pick-ups under the buttons with a pencil eraser or gentle alcohol based cleaner and then try to see if that helps you out any be sure to remove eraser particles before reassembling the controller
Universal Remote Compatability
Usually, any universal remote works on just about any tv. To find the codes, I suggest googling the remote model number +codes, or try to find instructions for an "auto search" so you don't have to keep punching in codes. Good luck!
Der Strom
Where can i get the battery 7100 coby TF in fresno and do they have one ?
Have you already removed the battery? There will be information on it telling you which battery to use as a replacement. As a general rule I would suggest you Don't start taking things apart if you are not sure what you are doing! You could cause more problems than you're trying to fix. Ask at your local TV repair shops and even some of the computer repairers. They may be able to help you. You would have to ask them directly if they have one in stock but commonly if it isn't a commonly used battery they will have to order one in for you.
If you have the battery details you might be able to get one online.
HOW DO I PROGRAM MY COBY UNIVERSAL REMOTE CRC-02
If you don't have the code for your device, you can use the auto search method to find the correct code. Here are the steps:
Turn on the device you want to program.
Press and hold the Setup button on your remote until the LED light turns on.
Press the device button (TV, DVD, CBL, etc.) for the device you want to program.
Press the CH+ or CH- button repeatedly until the device turns off.
Press the Power button to turn the device back on. If it turns on, the remote is programmed successfully.
Otherwise, you need to search for the manual for the remote.
Coby RC-028 under-the-counter television. on local channel 5 the audio is both English and Spanish. How do I turn off the Spanish portion?
If you are hearing both English and Spanish audio on local channel 5 on your Coby RC-028 under-the-counter television, you may need to adjust the language settings. Here are some steps you can try:
- Press the "Menu" button on the remote control.
- Use the arrow buttons to navigate to the "Audio" or "Language" menu.
- Look for an option called "Secondary Audio" or "SAP" (Secondary Audio Program). This option controls the language of the audio.
- If the "SAP" option is set to "Spanish," select the option to change it to "English" or "Off" (depending on your preferences).
- If there is no "SAP" option, look for a language setting or a similar option that may control the audio language.
- Save the changes and exit the menu.
- Test the TV to see if the language has been changed.
If these steps do not resolve the issue, consult the user manual for your Coby RC-028 or contact the manufacturer's customer support for further assistance.
