SOURCE: Dyson DC 17 Asthma allergy Vacuum
I had a similar issue. I called Dyson. Hey why not, the number is right on the from of the machine. SO IS the beater bar on/off button, right next to the big red on/off switch. It does have a safety off when something jams the bar from rotating so the motor doesn't burn out. I also removed my sock and on restarting the thing, the beater bar would motor was not turning on. I thought the reset would be inside but no, it is right outside in plain view, which I didn't see either. It is a grey button opposite the big red on/off switch. Boy did I feel dumb after that phone call!
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
SOURCE: dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
SOURCE: I have a Dc-25 Dyson ball,The beater bar does not
check to see if the belt is broken or loose and have a technician look at the clutch to see if its burnt out.
Testimonial: "it was somethimg simple, the wheels were'nt releasing. thank you. Bruce"
SOURCE: I have a dyson DC28
I had the same symptom with my wife's DC28. The problem was associated with the cam driven height adjustment mechanism. The beater bar must rock freely up and down when pressing on the tabs that the end cam lobes actuate. On ours I found hair and crud jammed in between the end of the beater bar and the side of the vacuum head preventing it from moving freely. To clean it out I fashioned a hook tool by straightening a paper clip and bending the tip at 90*, then took a flat screwdriver to pry the gap open a bit so I could use my tool to clean out the buildup.
I removed the plate that holds the cam in place (6 torx screws) to gain access to the rocker tabs, although in hind sight I could have probably just left it in place. It doesn't matter how you set the cam back into place. It's self aligning with the aid of the micro-switches inside.
Hope this helps
