SOURCE: Ipod Touch Sync Issue
Hello
Sorry I don't have much time to guide you right now
but start with this page here
http://support.apple.com/kb/HT1207
SOURCE: 8GB iPod Touch Disabled
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Plug the
usb cable into the Ipod and NOT into the computer.
Hold the
Home Button down for 5 second (do not release it)
Then
Press and hold the Power Button for approx 10 secs (count them out)
Your iPod
will reboot.
Release
the power button and continue holding the Home button for an additional 27secs.
You may
see the screen go blank or not.
Plug the
USB end into the computer with itunes open.
Your ipod
will mount in recovery mode.
Restore
it and Your all set.
if you need any further help let me know.
Good Luck
SOURCE: Does one have to have apple computer for ipod one touch
Uninstall everything and start fresh. go to download.com find the newest edition of itunes. Install it. Plug the itouch up and see if it recognises it and if it does your golden!
SOURCE: My ipod touch [4th generation] screen is stuck on the usb cord pointing toward the itunes logo
The solution is: 1. Turn of your iPod. 2. While holding down the 'Home' button, connect to iTunes WARNING: Doing this will return your iPod back to original 'out of the box' settings and you will lose everything. On the bright side, you get a 'fresh' start and it will auto update to the most recent software version.
ipod touch 4 gen
Insert the USB flash drive into one of the USB ports on your computer.
Momentarily a small prompt will appear saying the computer has detected a new removable device.
Insert the antivirus software installation CD into the disc drive of the computer to launch the installation wizard.
If you downloaded the program, double-click the downloaded file to launch the installation wizard.
Read through and accept the license agreement, then click "Browse" when shown the installation location.
A search window will appear on the screen. Choose the USB flash drive and click "OK."
Click "Next" for the installation name and select "Install." The antivirus program now will install onto the USB flash drive
hope this helps
Many software programs, games, and utilities have an
AutoPlay feature that will automatically start the setup screen for the
software program when the CD is placed in the computer. If your program,
game, or utility contains this feature, run the installation through
the screen that appears after inserting the disc.
If
you are installing a program, game, or utility that does not contain
this feature or you are installing a program from a floppy diskette,
follow the below steps.
An alternate method of starting the installation in Microsoft Windows
