SOURCE: Few12 will not spin after washing, any ideas
Had the same problem. Removed the kick plate at front and unscrewed filter. In the filter recess I found a cotton wool bud. Appeared to have stopped the blade like fan spinning which appears to push the water into the drain hose. Works perfectly now.
SOURCE: where is the filter on my hotpoint few12
Hi.
If you cannot find a filter at bottom right of washer, then remove lower rear cover, locate and remove large black hose on bottom of drum, you will find the filter in there.
Please rate my solution.
Thanks.
SOURCE: How do I clean the filter on my Hotpoint First Edition FEW12
Yes, remove lower rear cover.
Remove large black hose from bottom of drum.
Clean the filter inside the hose.
Thanks.
Testimonial: "Easy to understand"
SOURCE: my machine won't drain and I can't find the
After having removed back panel, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Hope this helps you.
SOURCE: My Hotpoint First Edition FEW12 Front Load Washer
the inlet vaulve is faulty. Is machine hot and cold fill? if so you will need to change correct vaulve.
