SOURCE: grinding noise when washer starts
hi there,
the grinding noise may be coming from either the pump or you have something caught between the drums.
the f-33 error is the pump drive system error. it indicates that you have lost communication between the CCU board and the pump. the CCU board is the main control board that you see in the front of your washer.
i would recommend that you call a technician to check it out, as you will have to do some checks that require technical knowledge.
SOURCE: washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
