20 Most Recent Frigidaire GLWS1233A Top Load Washer Questions & Answers
5answers
My washer will only spin clockwise not the other
HI. the internal components that make up the agitator should be inspected for damage.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cause this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
7/28/2017 10:57:37 PM • Frigidaire... • Answered on Jul 28, 2017
How do i disarm the automatic lock feature on a frigidaire top load washer
pause the wash cycle, it will auto unlock in a period of time
5/26/2016 4:37:03 AM • Frigidaire... • Answered on May 26, 2016
Water overflows
Washer fills with water and overflows: The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective. You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good ( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED). The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
4/1/2015 2:32:35 AM • Frigidaire... • Answered on Apr 01, 2015
2answers
How do you open the panel where all the buttons are?
the screws come off the back of the control panel
9/9/2014 11:18:10 PM • Frigidaire... • Answered on Sep 09, 2014
Why is my fridgidaire top loading washer so loud?
You didn't say when it was making the loud noise. During the wash cycle or spin cycle? An unbalanced washer will make a loud racket, too many clothes or actually not enough will make the basket bang around in there. If it has a center agitator, make sure it is tightened down. The screw is under the center Fabric Softener cup. That's the easy stuff to check. Now on mine, when you take the front panel off, I noticed that the hooks and springs that hold the basket up & in place and help keep it balanced, had actually over time had worn the round holes in the metal construction of the machine to oblong holes. Not much you can do about that. If the noise is coming from the motor, & you can't find a used cheap one, it would be more cost efficient to just use as long as you can and buy another machine. A loud noise could also be caused by a bad pulley. Hope this helps.
7/6/2014 2:24:12 AM • Frigidaire... • Answered on Jul 06, 2014
Washing machine working only one direction and not stopping even
It sound like you have a problem with timer get it check
6/1/2014 10:50:59 AM • Frigidaire... • Answered on Jun 01, 2014
Spin cycle extra loud
Good Morning Friend, I understand that the spin cycle is extra loud in your Frigidaire washer, model# GLWS1233A. I also see that you have grease splattering inside the front and right side panels at the bottom of your appliance. Certain amounts of clunking or gear sounds are normal in a heavy-duty washer. If you are hearing any rattling or clanking sounds, there could either be foreign objects such as coins or it could be belt buckles or metal fasteners. If you are hearing a squealing sound, your washer could be overloaded. Stop the cycle and reduce the load. Thumping sounds usually means this is a heavy wash load. This is a usual sound, but if it continues, your washer could be out of balance. Stop the cycle and redistribute the wash load. If you are receiving a vibrating sound, there are a couple of things that could be causing this.
    1)Your washer is not resting firmly on the floor. Make sure your washer is resting firmly on the ground as well as level. You will want to make sure that it is level from front to back, side to side, as well as from corner to corner. 2)The wash load could be out of balance. Stop your washer and rearrange the wash load. With you receiving grease splatters, depending on how much and how often, I suggest contacting your local authorized technician for assistance. They will be able to diagnose your washer as well as determine where the grease is coming from. Hope this is helpful. -Best Regards- WP
5/29/2014 1:50:36 PM • Frigidaire... • Answered on May 29, 2014
0answers
Frigidaire GLWS1233A Top Load Washer Logo
123 questions posted
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
disarm automatic lock feature frigidaire
  • Washing Machines
