Panasonic KX-TG1033S Cordless Phone Logo
A
Anonymous Posted on Jun 24, 2014
Cordless phones I hear static noise on my cordless phone after I dial the phone number. Phone still works properly just have the static. I have unplugged all phones but still have static. This is not on my phones connected with cord.
Craig
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jun 24, 2014
Craig
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7687
Points
5
1) unplug all phones
2) plug them back in and check line.
If you still have the issue,!take a corded phone with. Phone jack coed to your box on the outside of the house. Usually gray, unscrew the first box - you'll see modules there - the one with the last four of your phone number is the module we'll use. Follow the directions on the box to open that module - plug your phone into the module. Here's the important thing - if you don't hear static, then the problem is from inside your house. If you call att to come out they will charge you - but that's the whole unplug the phones and centralize your base better. However, if you still hear static in the outside box, it's an att issue and have to come out at no charge.
5 Related Answers
Anonymous
  • 65 Answers
  • Posted on Feb 25, 2008
SOURCE: delete old phone number on auto dial and add new one
go here and download users manual by clicking on file name
http://service.us.panasonic.com/operman/findmanual.aspx?model=KXT7630
A
Anonymous
  • Posted on Apr 28, 2008
SOURCE: I am getting noise on
I am getting noise on my cordless phone handset, the other party CAN hear it we have a hard time hearing what is being said. Other phones in the home work fine.
Anonymous
  • 385 Answers
  • Posted on Apr 26, 2009
SOURCE: cordless phone not connecting to base. no dial tone.
switch the A/C mains off 5 minutes
or
Re-register them to the base,
This resolves the problem
Regards
Richard.
Anonymous
  • Posted on Jan 01, 2010
SOURCE: My Panasonic KX-TG2352PW 2.4GHz cordless phone has loud static.
I don't yet have a solution, but I do not want to be obligated to pay for your advice...so I will find another way to solve the problem. Thank you.
Anonymous
  • 342 Answers
  • Posted on Jun 12, 2010
SOURCE: I have a Panasonic cordless phone.Display says
This can be cleared fastly by resetting it.
Loud static
Remove the batteries let them discharge over night. Place in chargers for 24 hours. If still static unplug all phones from all jacks. Plug in a phone...a different one from the cordless ones. to make sure the static is not on the line.
You can then try to replace the rechargeable batteries or get a new phone.
RE : Panasonic KX-TG6461 I installed this phone
thats an hardware fail , you need a service shop to fix it
I keep a dial tone, even when I dial a phone number...can't make an outgoing phone...I keep getting the dial tone. can you please help?
1) make sure is the phone is working good
2) there are tone dial
3) see the steps before o.k see ,if there are another phone having the same problem. The problem is service provider.
4) eliminate any background noise., mute the cordless handset before dialing.
God bless you
My panasonic cordless phone model # KX-TG2258S the handset works but when you dial or talk or even just pick up the phone you don't hear any noise at all. not dial tone but it does call out. you just...
Do you even hear white noise? If not, it sounds like your phone's speakers may be broken, or it has water damage. If your landline is connected to more phones, ask yourself these questions:
Do all of the phones have this problem? If so, it's a problem with your connection, not the speaker.
Is there a volume button anywhere on the phone or the base? Try turning it up.
Do my phones make a "beep" noise when i push the buttons? If not, did they used to? If they don't, then it's likely that the speaker is no longer working properly.
You may need to contact panasonic and see if they will replace it for you.
Hope this helped! Please rate my solution!
- Frankie
Hello i have a ge 28118 series slim dect
My phone is making a lot of noise and static on in coming call so bad I can't talk. out going I can't make. I put in the number to dial call does not go through ,but I can hear the dial tone. do I need a new battery or is there something wrong with the phone itself.
1helpful
2answers
I pick the phone up, no dial tone. Display says
We called the phone company.....There was a problem up on the telephone pole. They fixed it, no charge.
My home/land line phone will not get a dial tone
The disconnected message is generated by the telephone company. They should be consulted about that.
The noise and not being able to dial out sounds like a broken wire. If you call the number and the line is broken it should keep on ringing until the telephone company times you out.
It sounds as if you have more than one problem.
After you try some of these things give me some feed back.
Dial Tone but won't call out.
The problem was the main phone line not the phone itself
1helpful
When i dial and press the talk butto, i still hear a dial tone...please help
Please follow these troubleshooting steps;
Tip 1 of 9
Move the handset closer to the base. The operating range may vary with environmental conditions and time of use. There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, you can conclude that there is nothing wrong with the phone. Consider trying a phone that operates on a different wireless frequency.
Tip 2 of 9
If you subscribe to DSL service for this telephone line, DSL filters must be plugged into EVERY phone jack that has a phone. The DSL signal can cause static/noise, squealing (similar to fax tones), caller ID disruption and other issues on your line. DSL filters block the high frequency DSL signals from being transmitted to the telephone. If you are not using the DSL filters provided by the telephone company, this will cause static/noise and possibly caller id issues on your phones.
In most cases, we recommend you connect the plug end of the DSL filter into the telephone jack, then connect a telephone cord between the filter and your phone.
Please contact your service provider to obtain DSL filters and installation information.
Tip 3 of 9
Other electronic products (i.e., 802.11 wireless networking products, radios, radio towers, pager towers, cell phones, intercoms, room monitors, televisions, personal computers, kitchen appliances and other cordless phones) can cause interference with your cordless phone. Try installing your phone as far away as possible from these types of electronic devices.
Tip 4 of 9
To get better reception, try moving the telephone base to higher location. Relocate telephone base near a window if using telephone outside.
Tip 5 of 9
Excessive background noise will cause a speakerphone to fade in and out. Try controlling the background noise by turning off any audio devices near the speakerphone. Also, try to avoid interrupting the person at the other end of the conversation while they are speaking. If background noise cannot be controlled, you should terminate speakerphone operation and return to normal handset mode.
Tip 6 of 9
Disconnect any other equipment that is connected in series with your phone. If you phone begins to perform normally, there is a compatability issue with your other equipment.
Tip 7 of 9
If your phone shares a power outlet with a modem, or if it is plugged in to a shared surge protector, try plugging the phone (or modem/surge protector) in at a different location. If this solves the problem, re-locate your phone or modem farther apart from one another, or use separate surge protectors.
Tip 8 of 9
There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, there is nothing wrong with the phone. This is normal radio operation.
Tip 9 of 9
You may have a line problem. To test for a line problem, test your unit at another location such as your neighbor’s or relative’s house. If your unit works at another location, contact your local telephone company
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
