I've been having a problem with the bobbin thread tangling up and now I can't get the thread to pic up and sew. I have replaced the bobbin casing because it has a broken corner on the point but that didn't make a difference. I have purchased a sensor but have no idea how to install it to see if that is the problem.
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
SOURCE: its like it is getting tangled in bobbin casing
loopy on bottom means upper threading or tension is wrong
SOURCE: I can't keep the lower thread from getting tangled
Ensure that you have routed the bobbin thread properly. Also, if the bobbin case is not installed properly it will give you this problem. Ensure that the protrusion is touching the spring on the body of the machine.
