Canon PIXMA iP4600 Color InkJet Photo Printer Logo
A
Anonymous Posted on Jun 13, 2014
6c10a error Do not print, any documents.
4helpful
My HP laser jet M1120 MFP is repors error message when printing
Re install the tonner and then go to Printer & Faxes settings and delete the all kinds of pending documents and the go to print a new document and after taht send me the result...........what is happening.
Pcl xl error error: insufficient memory operator: rectanglepth position : 751 How do i correct this problem
Solution
The possible reasons for this error message are as follows:
  • The document is containing both image and text.
  • The font is not supported.
  • Embedded fonts are used.
  • A special plug-in is used.
This issue can be fixed by enabling the following option in Printer Preferences .
To access Printer Preferences , follow these steps:
  1. Open the Control Panel .
  2. Open Printers and Faxes .
  3. Right-click HP Color LaserJet CM2320 MFP Series PCL 6 , and select Printing Preferences .
  4. Under the Advanced tab, change the Print Data Optimization from Auto to Optimize for Text and Vector .
  5. Now try printing the document.
  6. If the document did not print then try turning the printer off then back on. Try printing the document again.
Rameshkumar . R
[email protected]
3helpful
Error code 024-747 is given when trying to print a specific Word 2010 document although any other Word 2010 document seems to print without any problems. Can you tell me what this error message means and...
In my case was like when i tried to print MS Word or Excel document (Xerox WC 5020 & WC 7120) i had to set "Original document size" in Paper Type option as same as "Output document size" in Printing preferences - it should help.
9helpful
Says 49.4c02 service error
This error is an outcome of Printing a document which is not supported by the Driver. It normally happens when the user tries to print a PDF Format Document. It is just an exception but this types of Format Documents are hard to print and cause this error. Go to HP website and check for latest or upgraded Drivers or for some Firmware Upgrade. An outdated Firmware can cause this.
Thank you Sir, Have a nice day.
Error in printing
there is a printer options at control panel, try to see if the setting is printing immediately,...
1helpful
Document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
1helpful
I have an HP Color LaserJet 3800 printer. I am trying to print a document and it keeps printing: PCL XL error Subsystem: GEDI Error: MemA L LocError Operator: ReadImage Position: 743
That means that the printer does not have sufficient memory tp [rint the document, if it is a text document (eg word) try to print pages in groups, if it is a different document try the following:
" I receive a 'PCL XL error' on my HP 4100mfp when making a 2 page copy as one page in duplex? Why?
The problem is related to a printer memory problem.
If following parameters are set in the HP 4100mfp you will receive and 'Insufficient Memory" error.
1) In 'COPYING' the 'IMAGE QUALITY' is set to 'BEST'
2) In 'ORIGINALS' the 'CONTENT' is set to 'PHOTO'
Following error message is printed:
PCL XL error
Subsystem: GEDI
Error: InsufficientMemory
Operator: EndSession
Position: 32
The solution is to set 'CONTENT' to 'MIXED' or 'TEXT' or set 'IMAGE QUALITY' to 'NORMAL' or you can add additional memory to the HP 4100mfp. "
from euroform.com - FAQ
Problem printing PDF document
In Print settings if using PCL select Print as Image. Also Spool Printing. Use PCL5e or PS drivers.
7helpful
5answers
Printing problems Kyocera KM 2050
try setting the driver to KPDL mode in the settings section of the driver
old marine
old marine
ZJ Limited
ZJ Limited
