While using this to cut through branches not to thick the cutter as fractured the metal part away from the part were the cutting blade attaches it will have to be welded should this accur very dangerous near caused an accident should the company know about this if so how do i contact
SOURCE: table saw blade wabbles alot when cutting?
This could be caused by several problems. First unplug the saw. Put a known straight edge against the blade (making sure not to contact the teeth) turn the blade slowly and watch for runout. Second make sure the spacers and blade flanges are on correctly. I would just about think it would be the blade. If you provide the model and brand I can do some more research. Good Luck
SOURCE: I have a JS660 jigsaw.
That is a common problem with those saws... the blade holder is a POS....
Some engineer's idea of a better idea that don't work in the real world...
Here is another review of that saw...
http://www.epinions.com/review/Black_Decker_JS660_Jigsaw_with_Smart_Select_Dial/content_493711167108
Don't know what else to tell you except that you may have to use a different saw....
I usually use my Milwaukee Sawzall for that job....I can place a longer blade in that and it works much better then a jig saw...
I have even used the old hacksaw standby already in a tight space...the bolts are brass and if you can get a groove halfway through you can break the top off from there...
heatman101
SOURCE: Black and Decker Jig Saw
If you haven't done so yet check the base plate bevel adjustment setting to make sure it is setting at a 90 degree angle to blade and make sure that the shank on the blade is not bent or twisted. Hope this helps. Thank you.
A pizza wheel cutter is a metal wheel that rotates through the pizza so you can cut it even when it's hot. A pizza rocking knife is a thick metal blade with handles that you can use to rock backwards and forwards through the pizza to cut it.
