SOURCE: Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
SOURCE: water leaking from dispenser into refigerator/French door bottom freezer
IT IS PROBERLY THE HOLDING TANK / TUBES LEAKING TAKE LOWER CRISPERS OUT AND CHECK THERE ITS BEHIND THEM
SOURCE: I have an LG LSC26905TT side by side fridge
When the filter freezes up, the outside casing may have cracked and will leak water when you dispense water through the door. You will need to have the filter replaced and that should take care of the problem. But the filter should never have frozen in the 1st place. You will need to call a qualified LG technician to see what's going on inside the refrigerator.
SOURCE: using without water filter
The effort it would take to eliminate filter would be too much. Just leave filter in place. If new house filter is working right you should never have to replace fridge filter and your water will be double-filtered :)
SOURCE: My side by side is not making ice anymore?
Tania, if your unit is only 5 weeks old you should call an LG service co to repair in warranty. you shouldnt have I/M problems this early
