The top stitch is fine and zigzag and underneath is loopy and no tension also not zigzag pattern?
There are a couple of things to check. First, did you thread with the presser foot UP, so that proper tension is applied to the upper thread? Is your bobbin correctly inserted, and is your bobbin case inserted evenly and correctly? Review your user's manual--if you don't have it, you can download it free at the Singer website.
If you have done these things, you may need to adjust your bobbin tension. First, run a line of straight and then zigzag stitches on a scrap of fabric and take a look. It helps to have two different colors of thread, with the fabric a third color. If one side of the zigzag looks fine and the other side looks like "chicken tracks," the chicken tracks side is too tight. In other words, you need to determine whether your bobbin tension needs to be tighter or looser.
You'll need a very tiny straight-slot screwdriver. Remove the needle plate--there are two screws in it--and remove the bobbin and then the bobbin case. On the side, there are two tiny screws. One is a Phillips--leave that one alone. The other is a straight-screw, and that one regulates the bobbin tension. The rule is "righty-tighty, lefty-loosey." Only turn it 1/4 turn, then reinsert and test. If you're on the right track, you should see at least a LITTLE improvement. DON'T do any more than that--if you don't do this carefully and systematically, you'll make things worse instead of better!
SOURCE: Singer 5050
I was hoping you would have got another answer, I have a mechanical sewing machine ( Singer 5040) with the exact same problem. However, if i use the programed stitches I can sew a zigzag. If i do it manually and set the zigzag width to any width ( even the widest) I get only the same straight stitch, and no mater what length I select it is the same too, very close to gether about 1 1/2 inch stitch.
I took my entire maching apart to expose inside both top side and underneath, nothing apeared loose or broke and i oiled it up. I bought a new bobbin holder and still the same effect. So it has to be something serious is my conclusion...sounds like a trip to Sears to me...LOL
SOURCE: Top stitch looks good, bottom stitch is loopy
this is a common problem, don't worry it's easy to fix. take the spool of thread off, remove the bobbin. look for any stray thread pieces in or around the bobbin case, rethread the top of the machine and when you do, follow the threading guide precisely and ---here's the trick---make certain that the thread goes between the tension discs.
SOURCE: loose stitches on bottom
FYI.. Loops on the bottom, problem is on the top..
Loops on the top, broblem is with the bobbin.
SOURCE: singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
SOURCE: Bobbin stitch is loopy
4 is the "middle of the road" tension number, but it depends on the thickness of your fabric.
