Hi Ajesh kumar, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?Hi Ajesh kumar, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
You need to send the correct codes to the printer. Use Caodesoft RFID or Batender automation to program the RFID Else you should send the programming codes depending on the RFtags.
Go to service centre.Mechanical assembly of your printer parts is somehow distorted.So do not try to repair yourself.Go to a service centre.Not a serious problem at all
Paper jam on this printer have several causes: - The size of the label is not correct (The legth mainly) - The type of Sensor is not correct. Transmissive or reflective. - You are using preprinted labels which affects the detection. To solve this you have to callibrate the sensors for the preprints. Check your manual or contact us. - there mays not enough contrast between the liner and the labels. You must check the sensors - Check if the sensors are correctly aligned. You may misaligne the top and the bottom sensors
Various possibilities: - The data cable on the head is not correctly inserted. - the head is out of order. - You are printing with a driver with a lower graphic resolution than the head resolution
