If you open door and rotate drum then it will start every time.
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
SOURCE: dryer drum does not turn
look on The back of the dryer. If their isn't a removeable back panel then lay dryer down and look inside for the belt or pulleys. One or both are probably bad.
SOURCE: I have the LG DLE5977S dryer. When I push the
The belt could be broke or the idler spring may have come of in either case you will have to take the machine apart to find out which.
SOURCE: LG Gas Dryer (dlg0452w) needs a push to get going
There can be many reasons why your dryer will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
SOURCE: I have a LG DLE0332W Electric Dryer. I push the
I have an LG TROMM DLG and I was having the same problem. A few days ago, I had the " check filter" light come on, checked it, took exhaust hose off, and blew it out (with my leaf blower- maybe not the best tool for the job) dryer worked couple of days and then I had problem you mentioned.
My best friend engineer neighbor came over to look at it. We took top off, turned it on, wouldn't tumble, we gave the drum a push with our hands, it started, we repeated that a coupel of times and now it's working, Seems like belt is fine, motor is ok- maybe something got caught in rollers, Hopefully fixed for good now.
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
