I have a Braun slide projector that needs a replacement lamp. The previous lamp was a BOFA 250v-300watt globe. Can you please advise me where I can obtain a replacement? None of the projectors look like mine.
SOURCE: model 808 (or 888?) Revere slide projector. Lamp
the fan motor bearings are dried or gummed up and need cleaning and relubrication. not a good ides to run without the blower. the heat can damage slides and blow the lamp.
SOURCE: I require a bulb for a Braun Paximat slide
Try checking with www.bulbman.com They have an amazing assortment of lamps for projectors!
SOURCE: h i I am looking
Hi guys - did you ever find the manual? Specifically, do you know how the remote is supposed to work?
SOURCE: the projector drops the slide
The problem you have is related to the cycle contacts in the slide change mechanism. The contact is probably worn through and the projector will just continuously cycle. An experienced technician may be able to fix the problem temporarily (by gently bending the cycle contact to capture the clutch spring). Because of the age of the projector, very few parts remain. You may want to contact www.micro-tools.com to check if they have parts available for your projector. They may be able to help you locate an experienced tech. Sorry I can't help you more!! Best of Luck !
www.yylamp.com
I am Maggie from Yue Yu Electronic and I am in charge of the export business.
We, specialized in multi-media projector system engineering and maintenance service, wholesale and retail all brand projectors and its accessories (lamps, ballasts, polarizer, light tunnels, filters, burners, main boards, LCD panels, color wheels, lens, remote controls, etc.), have exported projector parts for many years.
If you need any projector parts, do not hesitate to contact me.
Email address: [email protected]
www.yylamp.com
