The implements
each have adjustable heights. to adjust the height you need to loosen
the bolt at the top with a 14mm spanner. If the bolt was loose when it
was being used then it can get too short and not leave enough clearance
between the bolt and the machine in order to push up and turn to release
the implement. If this happens take the open ended spanner, grasp the
implement and rotate the spanner clockwise (when looking up at the
machine from below. Once the nut is loose rotate the implement until
there is enough clearance to remove it normally.
Found a kit on ebay for 9.99 which fixes the speed cntrol problem on 901 chefs do a search for kenwood motor repair comes with instructions you would need to be ok with a soldering iron
It is most likely a burnt out capacitor. They can be replaced for about £30, but it is not a DIY job unless you know a qualified electrician, there is soldering involved!
