The only buttons that work on my remote are change channel (up/down) volume (up/down) and on/off button! (First thing I did was replace the batteries) No other buttons work and I cannot seem to work the TV manually either! Ever seen this before?? Can it be repaired or do I throw it away and get a different brand? Thanks in advance. Shan.
SOURCE: Remote not working
I have the same TV, and it has developed exactly the same problem! Hopefully there is a solution...
SOURCE: Samsung LN19A330J1D TV buttons on monitor don't work
You may have to enable them within the menu as these type of TV's are often used in Hotels and Hospitals and what not. Disabling the buttons on the TV prevents customers from messing with the settings of the tv and allows the business to use whatever custom remote they prefer. Check the on screen menu and look carefully through the options, you should find it there.
SOURCE: remote not working!
Hi, I have just had same problem and rang Samsung who sorted it ! All that was required was to reset remote by taking out the batteries then press power for approx 10 seconds and then replace the batteries and hey presto it worked!
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
SOURCE: cox universal remote won't control samsung tv ln52a650 volume
This is a tough one, I can come up with possibly 2 solutions, 1 being that if the batteries are low you will sometimes lose partial control of some of the functions on the remote, and if that is not it, then I have another that this one happened to me once, The infrared on the TV was not picking up the volume button I was sitting at an angle, so everytime i sit in that chair everything works but the voulume control i have to point it right at it on direct line and not from the side...Hope this helps...Steve
