20 Most Recent Samsung LA40A450 40 in. LCD TV Questions & Answers
My samsung tv sound keeps cutting out. I have to
either you have a loose connector going to speakers or the main board is failing.call 1-800-samsung for nearest service center.
10/31/2019 2:00:08 AM • Samsung LA40A450... • Answered on Oct 31, 2019
Will a Samsung 40" - 42" HD TV hook up and work
I haven't had any issues reported to me regarding any incompatibilites with samsung TVs. Also our equipment is compatible with almost any TV so my bet would be that it's compatible, you may check Samsung's website as well.
Daniel Busa
DISH Network
Customer Service
1/2/2019 3:06:33 AM • Samsung LA40A450... • Answered on Jan 02, 2019
2answers
When I switch on my
This problems could be also causes by the board the call the T-CON docoders board,it sit in at middle of the bottom of the LCD screen panel.Because this board decoders incomming pictture signal before it go into the LCD screen panel to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoderd board for the replacement.
9/3/2016 12:00:18 PM • Samsung LA40A450... • Answered on Sep 03, 2016
2answers
My Samsung LCD TV (40A450) 40 inch, when switch
The capitors on the back might be bad this I have fixed on these tv's many times. That could be one of the problems and the capitors are on the power board inside the tv. If you do not know how to work on electronics I would have a pro do it they contain hight voltage so be careful if you try to fix it yourself.thanks
2/19/2016 2:01:30 AM • Samsung LA40A450... • Answered on Feb 19, 2016
LA40A450CI no baclight
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
12/26/2014 3:58:39 AM • Samsung LA40A450... • Answered on Dec 26, 2014
2answers
LCD TV LA40R81BM/XTL tv tick tick sound 5min then strat
Hi my name is Roety,
I can help you with your issue ,
This is most likely a power supply issue
I usually replace the swollen capacitors I can see
A repairman would charge about $300 to replace them for you.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
11/10/2014 12:32:25 PM • Samsung LA40A450... • Answered on Nov 10, 2014
Why is my Samsung lcd tv stuck on standby
Theres probably a fault in the power supply board and the tv is shut down to protection mode
9/22/2014 11:46:50 AM • Samsung LA40A450... • Answered on Sep 22, 2014
NEGATIVE COLOUR DISPLAYED
Sounds like T'Con fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
4/20/2014 1:30:24 PM • Samsung LA40A450... • Answered on Apr 20, 2014
SAMSUNG PLASMA PD43A450
You should have to contact the authorized service centre for Samsung in this case. Plasma screens are not available by open electronic spare part market. Gopakumar Gopalan Google
3/21/2014 6:40:50 PM • Samsung LA40A450... • Answered on Mar 21, 2014
Ssi400_10b01 schematic diagram
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
3/13/2014 2:36:12 PM • Samsung LA40A450... • Answered on Mar 13, 2014
0answers
0answers
My samsung LE40A656A1F has white horizontal lines through it?
FixYa expert monitors advised me to not give people this advice, but I am a TV repair specialist with pretty solid experience in LCD and plasma TVs and there is only one good advice I can give for those cases.So I am a bit in a conflict here as the website managers asked me not to tell people what I know is the best.So I won't.I am not telling you to replace the TV and I am NOT telling you to not waste time trying to fix this.There...I didn't say it!BTW the hiding and re-appearance of the line(s) had really nothing to do with the cable at the back; it had more to do with you applying physical pressure to the TV frame, something that may yield some result even now, but it can't be used to successfuly restore functionality in long run.
12/25/2013 11:44:20 PM • Samsung LA40A450... • Answered on Dec 25, 2013
0answers
0answers
La40f7 LCD Samsung tv no sound
Do you have video? Start with making sure the "Mute" feature isn't turned on. Also check the menu, some sets give you the option to turn off the internal audio !!!
11/11/2013 5:50:29 PM • Samsung LA40A450... • Answered on Nov 11, 2013
No Sound on a la40f7 LCD samsung
Check its speaker/s first. If found OK, check and replace damaged component/s at its audio output section circuit. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
11/11/2013 9:11:14 AM • Samsung LA40A450... • Answered on Nov 11, 2013
0answers
0answers
Samsung LA40A450 40 in. LCD TV Logo
109 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LA Samsung
  • LA Samsung
Most Popular Question
  • Televison & Video
